bronco pulling to right
jimbos71
just wondering if it is normal for a possi rear end to kinda twist the truck on serious exeleration and serious deceleration it does it too . it seems I need a rear end stabilizer or something . or could it be the front tires , as they were worn prior to me getting them , the wear is heavier on the inside by about half inch . ??? also when I am on gravel it seems very easy to spin the tires when I try to back up . ??
SteveL
Huge chevy guy
Hawthorne ca
Check your u-bolts on the leafs. I cracked one and it did that real bad. It could be worn bushings or leafs. It is also possible you need one of the kits to prevent axle wrap. WH and JD sell a couple good options. I would check for worn parts first before sticking a band aid on it.
broncnaz
Yes posi can cause torque steer. but as was said check for loose parts and you may need to get the front end aligned ity might help a little. As far as spinning the tires in reverse its pretty common reverse is a low gear and the suspension doesnt quite flex the same way when in reverse due to the shackle position so its a little easier to spin the tires.
