I have a bone stock 74' Bronco with a 302ci / 3 speed, drum brakes. The brake light is on and will not go off despite a full four wheel brake job. Under hard braking, the car will pull to the right as well. Any help would be appreciated.
You either still have some air in the system or you have a leak somewhere. After you get the pull fixed be advised that the brass brake warning switch is very prone to sticking in it's bore. I had to pull mine out, disassemble, clean, put it back together, and rebleed to shut it off.
not realy same as porp.valve.mounted under master cyl on frame.baiscly just a junction block.real pain to get it centered.if brakes are bled and adj right piston will be centered and light should go out.
