Broncorod: build thread
Bronco Biff
soft top, no-top, half cab top, full top.......have all 4!!! ok, maybe scratch the full top!
E
ehumaui
Lost lower dash brackets, had to make some.
E
ehumaui
She wont start..,, checked all connections, had battery and starter tested. I at wits end.
A call to our favorite bronco guru dirtdonk. We went through all the possibilities, of corse the last thing was the engine bay painted recently ..,, ah ya. The solenoid did not have a good ground . Dont forget to groung the body.
Thanks Paul your the man!
Russ
E
ehumaui
Little work this week. Set rivit nuts for bulk head, since the body did not have any. The hand tool sure made a difference,.
E
ehumaui
Also had the muffler shop redo the exhaust 2 to 1 to a magnafow
E
ehumaui
Fitted half cab. On and off body so many times. Scratched and chipped paint. Not to happy. Soft doors now dont work. No room to adjust. May be not a good idea to change a truck that was not set up for a half cab?
You've been a busy guy there Russell!
Obviously been awhile since I've stopped by, since the last thing I remember is the body still on the rack, and not on the frame! Gonna have to do a drive-by one of these days.
Keep on it. It's "almost" there...
old 71
That rig is sweet, perfect color, always liked the look of a slammed half cab.
Keep up the good work , almost at the finish line.
Dale
E
ehumaui
After a cool down period, clear head and back on it today.
Unbolted bulkhead and refitted the soft window frames. Adjusted to fit. Had to shim the body to get the top to lay flat. Rebolted the bulkhead back on. I have a 1" gap at the sides. Will fill with something latter. Still have a slight lift a right front corner.
Enough for today.
RC
E
ehumaui
Had body shop do interior and exterior in off white. Looks smooth.
Rc
