Building a 5.8L for EFI
casadejohnson
Bronco Alchemist
I already have a 351w and EFI in my 74 Bronco and it runs great. The current engine is a 69 351w remanufactured back in the early 90's, its bored 30 over and sports later 80's heads. Pretty much a stock 351w. I plan on donating this engine to my 68 Bronco that we are starting on for my son. To replace the 351w, I picked up a 96 5.8L roller motor out of an F150. I want more power than I had in my old 351 but nothing crazy. How far can I go with it and still have it play well with my A9L computer and Mustang wiring harness?
I think my biggest bottle neck in the current motor is the 80 something heads so I was thinking of getting some aluminum heads for this project. I'm also assuming a cam change will be in order. Most of what I have read about building these engines is more geared to the Mustang crowd and carbureted engines so I would like to see whats working well in other Broncos. I can justify the $ for heads, but a full on stroker motor will probably be more than I can spend on this.
I plan to be reusing my Edelbrock performer intake, Explorer Throttle body, and 70mm Mass air meter. I also run BC headers and 2 into 1 Exhaust. So, the question is, Am I going to see a significant change from what I currently have by using this new block with better flowing heads? If so, what heads? I hear, "Just get some AFR's" but there are ton's of options out there. How about cam's? Back when I ran a my 351 with 31's, It was a beast when you hammered the skinny pedal. Now I'm on 35's and its much less impressive, I would like to get some of that feeling back in this process. I'm open to suggestions on workable combinations.
Here is a few photos of the 5.8 and my helper in the tear down process. Also a photo of the 351w currently under the hood.
Amac70
ME
when i built my last 351 i to wanted significantly more power then i had. I basically went with a stock lower end and camed and aluminum heads. night and day difference. Heads i found on craigslist just edelbrocks performers with springs rated for a roller cam. before i bought these i was leaning towards trickflow 185's. im not an afr fan(and i have no real reason for that.) As for cam i went with a comp cam 35 510 8 for a little more you can get a custom grind but this cam has worked very well for me, lots of power off the line then really pulls hard from 3k to 6k. its also efi compatible. don't let any one talk to you into a stock cam they flat out suck compared to this one(i ran the stock cam before this one.) The comp cam has lots of lift short duration kick in the pants to drive.
broncnaz
I think the 96 5.8 was a speed density motor but dont know if the system is as good as the AL9. In any case getting your computer tuned to your engine and its mods will be the key to getting the most power out of it.
Just about any aftermarket head you chose will be a improvement over the stockers. I dont think we need to have the best flowing heads on broncos as we rarely spend time in the range that they work best at. So really AFR's are nice but they really dont put out much more power than most of the other heads out there. So basically take your pick.
Cam choice is a hard one it depends on what your gearing is and where you want the power to be. The stock roller cam is a good lowend cam should work well and is good for OD. Your jump to 35in tires and lost performance says that gears may be needed. a bigger cam wont help lowend performance. Also keep in mind that bigger heads also move the power band up in the RPM range.
Basically Id figure out if my gearing is where I want it then build the engine around that. If you want a wild motor then you will definetly need more gearing.
casadejohnson
casadejohnson
Bronco Alchemist
I'm running 4.11 /4.10 factory gear ratio. I know many would say I need to be running 4.56-4.88's for 35's but I really don't want this thing wound out every time I want to go above 60 MPH on the highway. I did ARB's last summer and could have regeared at that time but decided against it. As for heads and cams, I have a lot to learn. The options out there are endless so that's why I'm curious about what others are running and liking. That at least gives me a starting point of what to look for. I'm not doing any drag racing but it would like to feel the difference when I'm done. I wish I knew what my current engine was putting out for torque and HP but I have never had it on a dyno to see what the numbers are.
casadejohnson
casadejohnson
Bronco Alchemist
Motor looks really clean inside.
Yea, it was much better than I expected. The outside looked pretty nasty so my hopes were not very high that the inside would be any better. All I did to clean up the cylinders was poor a little gas in to each cylinder bore, let it sit a few minutes then wiped it out..
I'm thinking I will leave the bottom end alone other than maybe a ring job. I was trying to determine if this block has ever been bored out at all. Should the cylinder bore be exactly 4" if its unmolested or is it a few thousandths more than 4"?
Ourobos
Big Island Hawaii
Since the intake is going to limit your HP with a good set of heads and a good cam, you can push the A9L to 24# injectors and meter, and still get away with not needing a tune, if it's mass air. Speed density too, if you run a cam with a 114 degree LSA or greater. I've built them from stock to 700hp, once you get your injectors much bigger than 24, a dyno tune is usually needed.
rguest3
351W F4TE Block with 9.4 Compression
Lightning GT-40 Aluminum Intake
Aluminum Heads - 170-190 cc intake runners
Comp Cam - XE266HR with 114 Lobe Separation
ProM #24 Injectors and Matching Air Meter
BC Headers with 2 into One
Have built this combo before and am currently doing the same. NO tuning needed with A9L/A9P and RJM Harness.
Great Low end torque and very good RPM range. Slight lope at idle.
Ourobos
Big Island Hawaii
^ Sounds like a winner. Funny because I'm piecing together my 351 based engine for my 72 right now, and had planned on that exact camshaft. As for heads, I'll probably go with a AFR165, and intake either a GT40 based or possibly a Performer RPM.
Let it breath
Give it the squeeze
Go a little mild on the cam.
Find a good intake. Find a good intake. The BC adaptor is great for a stock engine. But wake a 351 up you will start needing something like the lightening intake. That will flow more air then the stock 19Lb injectors will flow, as well as the stock mustang MAF. At this point The A9 computer will do best with a custom tune. This can keep you away oddball MAFs. Just use a stock MAF for an engine that makes your power level, have the tuner put that transfer table (programming that matches the MAF) into the computer. Same for the injectors. and about a dozen other options they will offer to you.
Don't be afraid of a bit of compression. Compression is a wonderful thing. It is a world of difference between a responsive engine and a lazy engine. Aluminum heads will let you add a good point (and maybe more) over cast iron.
Then don't max out the cam. Keep it a bit mild, something with low end torque in mind.
My last 351 was GREAT. Others all loved it as well. Basic combo; trick flow heads, Summit house brand cam (flat tappet .471/.422 lift). Intake was carb based. Exhaust finally ended with a set of cast iron reproduction 289 K-code manifolds (port matched). The compression was a little excessive at 11:1, really pushing premium pump gas. I recommend less, low 9s to mid 10s depending on fuel.
casadejohnson
casadejohnson
Bronco Alchemist
I guess I didn't realize that the A9L could handle 24 lb injectors without tuning. I also read that there were actually 24 Lb injectors used in stock applications from Ford so you can find them in the yard without breaking the bank. I'm reading that they were in 95-up Lincoln Continental DOHC 4.6's. Anything else they would be in?
casadejohnson
casadejohnson
Bronco Alchemist
Let it breath
Give it the squeeze
Is the GT40 intake better flowing than the Edelbrock performer? I thought I read that the Edelbrock had a slight edge (Read it on the internet, must be true!). I bought the Edelbrock upper that I run used and whoever owned it before me did some port work on it. Did they do a good job?...No idea. Was your combo run with 24Lb injectors?
baddad457
The only thing you changed in the cam swap was add more lift. The duration vs the Explorer cam (F4TE grind) is nearly the same (256/266 vs 258/266) The LSA is slightly less too vs the F4TE 112 vs 116.5
baddad457
The 96 roller 351 is a Mass-Air setup. Got one sitting in my carport in a 96 E150 van. Got another (97 though) sitting on the engine stand out of a F250
00gyrhed
the roller cam in that engine isnt really that bad. It makes good low end torque. The intake manifold, e7 heads, and the sock exhaust manifolds are what dogged the 351 rollers. my buddies 3/4 ton truch with nothing more than GT heads, eldbrock performer mainfold and headers on the roller block with stock cam made you think he really had something special.
be careful its a never ending spiral. :) need headwork, just buy aluminum heads, need crank ground just go ahead and stroke it, thats how I got where I am.
Don't know which intake flows more. I will call them comparable. Way better then using a 5.0 car upper on a truck lower.
Can't answer the injector, was running a throttle body EFI. Never made it to port injection. But I would have ran at least a 24, if not a 30 LB injector. With a tuned computer (not a tuned MAF).
casadejohnson
casadejohnson
Bronco Alchemist
Just for informational purposes, I found this list of injectors over at stangnet.
Obviously, I have no confirmation on its accuracy, but the list will be going with me on my next junkyard trip.
Ford 19lb injectors (high impedance) #s: E5TE, D5B, F78E, F6VE
96+ Explorer 5.0 has better 19's than Mustangs
Ford 21lb injectors (high) #s: D9B, F65E (305/350 GM)
Ford 22lb injectors (high) #s: FOTE-D9B (vetts and range rovers)
Ford 23lb injectors (high) #s: F7TE, F8TE (7.5L truck)
Ford 24lb injectors (high) #s: F5DE, F1TZ, F2LE, F2LE-9F593-B2A, FMS-M-9593-A302
Ford 24lb injectors Ford 93-95 Mustang Cobra
Ford 24lb injectors 93-01 Lincoln Mark 8
Ford 24lb injectors other DOHC 4.6
Ford 24lb injectors 88-97 EFI 460's F250-450 & E250-450
Ford 24lb injectors Lincoln Aviator w/4v 4.6
Ford 24lb injectors Lincoln Navigator w/4v 5.4
26lb '00 LS1 F body, maybe '99 to?, same as Ford 24's
Ford 30lb injectors (high) #s: E9SE, F1SE, F1SE-E1A (3.8SC and SuperCoupes)
Ford 30lb injectors: 95/96 Ford 4.0L Explorer & Ranger & Other **I've read confirmed reports of this being wrong check part numbers before you buy! **
Ford 30lb injectors: 89-93 SuperCoupe
Ford 36lb injectors: 94-95 SuperCoupe
Ford 39lb 03-04 Cobra
Ford 42lb 99+ Lightning
broncnaz
I goofed that one meant to say mass air. I think 95 was when they went to mass air.
broncnaz
What tranny are you running? A step up to 4.56 will only move the RPM's up about 200 RPM 4.88 up about 400 RPM neither of which I would consider winding out. Of course a OD tranny would bring the numbers down and still give you the lowend grunt you want.
Basically with lowering gearing and no OD you can run a bigger cam as any power lost on the low end is not noticed because of the gearing. With not so great gearing you need the smaller low end type cam as you wont get into the higher RPM's
For head choice Id pick something you like for the price. as was said keep the intake runner size down maybe in the 170cc range and you should be good. bigger ports kill volecity and lowend power to a degree. Many aftermarket heads dont make much more and some make less power than stock heads below 2000 RPM.
Just from my personal experiance I swapped to aftermarket heads on my 73 one weekend when it was a DD. While for me it was kind of a night and day swap because my stock heads were messed up I didnt see a huge increase in power. Of course probably because the heads are a little to big for the engine but I did see a increase. I can really tell the differance in the hihger RPM's tho as it pulls very good.
If you look at dyno tests of most aftermarket heads you will see most of the power increases are at the in the mid to upper RPM range where we dont run as often.
Hard to really say for sure about you old 351 and what it put out for power a lot depends on the year and how it was rebuilt. could have anywhere between 150 and 210 hp torque is around 270-300 for both. the later 5.8l with EFI and roller cams were about the same 210/320.
