Building vs buying axles
buckenbronco
Hanson
To me it seems like you can build the ford 9 inch and the Dana 44 a lot cheaper with good components then buying it all done. I’m thinking a complete 3rd member with trac lok. 35 spline axles, wilwood breaks, powder coat,truss. Full width. What’s so hard about bolting that together for a lot less. You price it out from curry or mosier or another place and it’s huge money. Or am I wrong.
samamarshall
All depends if you have the know how to DIY, have the additional tools you'll need, and more importantly, the TIME. I'm getting the third member complete to avoid the gear setup, etc. but doing the rest myself. Not sure about the Dana 44 yet...might send that off to someone local to save on time.
yakelys69
I try to avoid feels like & seems like. Put together a list with current prices based on what you have / want then let’s talk.
73azbronco
My experience? I didn't have the tools, and experience, so it was far cheaper to have it done.
bmc69
I've built quite a number of front and rear axles for off road rigs. I have a fully-equipped fab shop and the right tools and the know how. So of course it's "cheaper" for me to build my own than buy them already completed. But...if I included the value of my time, and amortized the cost of all that shop equipment, the total cost would be same...easily the same.
Timmy390
Conway, AR
I did my front and rear......did a bunch of reading and got advice from those here. Found a how to rebuild for both and got the tools at harbor Freight with the exception of the "setup bearings" needed for the front. You can make them however a member here let me borrow a set for the cost of shipping. You don't need a case spreader for the front. There are ways around that and for the 9 you can use a solid spacer and not have to deal with the crush sleeve.
I wouldn't consider the front or rear hard. Rear is "more easy" front is just more time consuming and has a few different steps.
I had never done one before nor even see how one was built. If I can do it anyone can.
Tim
When you start putting words like "truss" into an axle build, you are no longer in the game with a stock housing. At a minimum of a heavier big banjo housing if not just going to one of the beefy aftermarket housings. And you are not reusing the stock 3rd member, There are too many beefed aftermarket ones that are better matched to the stout housing. So you are not using any of the stock parts. It is simply a matter of collecting all the right parts and putting it all together.
The front axle is a bit different. They are not as available as the generic 9". You really need a Bronco D44 housing to start with. If not you are doing custom work. At this point you are looking at having someone build your axle or do it yourself. I don't know of any crate front axles.
Timmy390
Conway, AR
I would go Truetrac vs. the T-loc.
I busted my T-loc within a few Weeks of upgrading to my 351W. Had to rebuild the 9 again but went Truetrac. 2 years no issues....
Tim
Boss Hugg
For sure, when you buy them built, you're paying for the builder to spend his time using his tools that cost him money to build you a product that he then REALLY needs to warranty. Or you can do as Timmy and I both did, spend the money on the tools and manuals and whatnot, so that you can the build more later which drives the cost of the tools down.
Last summer I bought the stuff required to narrow and 9". I then cut a Big bronco housing down and put new ends on it, along with a Grizzly and 5.13 gears. I thought one of these days I'll build another axle for a second project that's still years out. However, I bought my dad and I some antiwrap bar kits for both our rigs, and in welding the brackets on the housings, we found the housing gets bent (badly) from all the welding. So that narrowing kit came in handy when trying to straighten the housings. Saved the day, really.
So it all comes down to the tradeoff between your time and your money. Do you have the time to learn to do it yourself (and the money to buy the equipment) or do you need to spend the money to pay someone else to do it quickly?
That's my reasoning on why I do what I do. I built a house. Paid a contractor to do one thing. Hang sheet rock. After seeing their quality, I wish I'd taken the time to do it myself. I realized I had been screwed for beer money because the finisher that had recommended them never showed...
So I choose to do things myself and know what I'm getting.
needabronco
Prescott/Farmington
Its always cheaper to do it yourself, even if you have to buy tools. Unless you are a complete bafoon who can't boil water, teach yourself a new skill......
bmc69
Its always cheaper to do it yourself, even if you have to buy tools. Unless you are a complete baboon who can't boil water, teach yourself a new skill......
Is it though? The cost for the welding and cutting equipment, measurement and setup tools, etc adds up pretty quickly and also assumes you have the shop space, sufficient AC power etc. If you are building one set of axles for one rig...I'd have to say the math is going to look like "fisherman's math" *
To be clear, I'm not talking about just gear/dif changing. I'm talking about what the OP is talking about; a seriously built and heavily modified overall axle assembly.
* saved $24 by catching my owns mess of fresh fish. With the $12,000 boat and trailer behind the $30,000 truck I bought to tow it with. ;D
needabronco
Prescott/Farmington
Bill, were talking about building axles here.... I'm assuming that means installing lockers, upgrading axles and breaks and setting up gears. If you aren't going to do this professionally you can get away with harbor freight tools for that job.
bmc69
Lots of tools implied in the OP's "wish list" though:
I've probably built a dozen or so off road axles that I would consider "heavily modified". The last D60 front axle I built for a Bronco had over $2600 of just bought parts and a silly number of man-hours in it by the time it was under the Bronco and all all connected up...and I used a long list of expensive tools to get it there. I've also doe a couple rear D-60 35-spline axles, where you have to cut the spindles off, bore them out on the lathe, and weld them back on nice and true.....
It obviously all comes to down to the final list of things you want in/on it, what equipment, tools and skills you have...and heck, I never hesitate to buy yet another tool whenever a need arises. You never have enough tools...;)
JSmall
I built my own and here is an itemized list of everything that I have into it. I didn't want to go with tons so I built what I'm hoping is strong enough to hold up to 37' tires.
Apogee
Tangent, OR
Having just (almost) finished building a full-width, back-trussed F150 9" for my EB, you might come out ahead moneywise at the end and have some tools to show for it, but I doubt it...and certainly not if you value your time. To be fair, I'm pretty slow when it comes to this stuff, but I started with a F150 9" housing, trussed the back with a Rough Stuff truss that needed to be cut apart and fit in 3 pieces, then fully welded. I made some custom leaf spring mounts to eliminate the U-bolts since I wanted to try that and welded those on. I put it under the truck and realized that I rolled my pinion angle the wrong way...@#$*^$...cut it back apart, reset everything and rewelded it. I also put new housing ends on it and built a center section with an ARB. Just bolted it up yesterday and the pinion angle looks perfect, so now I just need to figure out my shock mounts, brake hard lines and install the drum brakes. After that, I'll machine some hub-centric registers to make mounting my wheels and tires easier on the axle and call it done until I think of something else.
While I already had most of the tools(welder, milling machine, lathe, indicators, hand tools, etc), finding the time is the killer for me. I probably would have been money ahead to just buy a Rough Stuff housing and call it a day. All the fiddly-farting around with the truss and custom leaf spring mounts and I probably could have put a 4-link in it instead and saved some headache.
Timmy390
Conway, AR
The tools needed to build a housing and or extensively modify one can get $$$$ I don't even know what's involved with modifying axle shafts. I just bought new.....
Now if all your doing is say changing the ends on a 9 (I've done this with excellent results) then the extra tools needed are minimum.
I would buy the housing and axles then setup the centers myself. I've found it's the shipping that's the deal breaker and forces me do do things myself when I can.
Tim
bmc69
...and you obviously own a well equipped shop...which was my point earlier.;)
Rustytruck
Well didn't that add up quick! There's a huge amount of work there in that rear axle. That's allot of fitting and inches of weld.
Boss Hugg
I don't know... that's really questionable. Maybe with another 10lb of wire??? LOL. ;D
