crutch
- Jul 3, 2015
- 249
I’ve got a rebuilt 347 Stroker that I’ve only got about 1,500 miles on and it’s consuming oil, not sure how to measure it but its quite a bit. Motor was running really rough and when I checked engine it was really low. Wasn’t sure why it was so low since it doesn’t leak much. Did an oil change and it ran good but I’ve been checking oil frequently and its burning oil. A few things I’ve noticed:
* It smokes out the exhaust on startup
* The oil pressure is up over 70 (higher then I’ve noticed it in past)
* Checked a plug and oil on it in the threads (see pic).
I’ve been looking through other threads and seems like it could be PCV, piston ring seals or valve seals. I’m using the Bronco valve covers which have baffles on them and connected the PCV on passenger side to the Holley Sniper vacuum and the other side is just a filter breather. The PCV pulls vacuum when I test it.
From what I’ve read, a compression test and leak down test will help isolate the issue. Is that the next best steps? I guess I should pull all the spark plugs and see how they all look. Any other thoughts/ideas?
A few pics of the engine for reference. Thanks!
