Engine is a 1971 302 block stroked to 331 with COMP Cams Xtreme Energy 268H camshaft and GT40 heads with 1.6 roller rockers. Bottom end wears a windage tray and 7 quart Canton pan. Idle is rough and vacuum bounces rapidly between 11 and 14 inches.
2017: The first valve covers were baffled Bronco script with a stock PCV valve. My oil consumption was a quart every few hundred miles. Not good.
2018: I installed the tall Summit covers and do not remember a PCV grommet in them so I ran breathers in both. No oil consumption in this configuration but I eventually developed several oil leaks. Not good.
2020: Read about M/E Wagner and their DF-17 Dual Flow PCV Valve from a link posted in a thread on CB. I searched for a PCV grommet and found that Moroso p/n 68772 fits the 1.22 in. diameter hole of the Summit valve covers. I pulled the cover, removed the metal baffle, and installed the Moroso grommet. This grommet is about 1.25" deep with a slit at the bottom to create a baffle. Drove 200 miles with this and sucked up over two quarts of oil. Not good.
Making no other changes, I installed a Moroso Air-Oil Separator. Probably not really needed but I wanted to see how much and when the PCV was sucking up the oil. Idle was good but with 2000 RPM it sucked about 1/8 of a cup in five minutes. Not good.
M/E Wagner recommends 3/8" (.375) minimum clearance between the baffle and PCV valve. I pulled the valve cover back off, removed the Moroso grommet and reinstalled the metal plate baffle. I then cut the bottom inch off the Moroso grommet so there are the two lips (top and bottom) to hold it in place like a regular, non-baffled grommet. Bottom of the grommet to the baffle is .390". I used the 1/8" spacer provided by M/E Wagner so the valve sits flush with the grommet.
After proper tuning of the carb and M/E Wagner dual flow PCV valve, idle and 2000 rpm checks showed no oil consumption. 30 mile round trip test drive, split evenly between country road and turnpike, also showed no oil consumption. Finally! Problem solved.
Parts list:
M/E Wagner DF-17 Dual Flow PCV Valve
Moroso Air-Oil Separator (p/n 85531)
Moroso PCV grommet (p/n 68772)
Summit Racing® Diecast Aluminum Valve Covers (SUM-440406)
