I just noticed the vendors are offering pre-lube grease for installing the C-bushings. Has anyone used it? Does it help to avoid or mitigate the infamous Bronco lean? I'm also curious if rubber or poly are less likely to result in the EB lean?
I would assume they are a 2 Degree.
I was hoping poly with grease may self correct in a similar scenario.
I mentioned the tendency of poly to squeak in a general sense. I've used them for sway bars almost exclusively since the early '80s and in that application they did squeak. Some even came with zerks, so the manufacturers were clearly aware of the squeaking. I have no interest in lifts of any kind. My '77 got it's lean when I hit a hole that was full of soft mud. When the wheel hit the far side I hit the steering wheel. From then on, it leaned. So improper installation isn't the only cause. I believe one or both C-bushing shifted. That was in 1980. Nobody knew about a fix then. I just swapped the springs side to side with no improvement. I was hoping poly with grease may self correct in a similar scenario.
