68rockcrawler
- Sep 18, 2006
- 1,417
Hey guys, I put a C4 and 4 speed Atlas in my Bronco a couple of years ago and only wheeled it a couple of times since doing so. It hasn't spent any time on the street with this setup. I had a T18 and stock Dana 20 before that. The Atlas is the 10.34 only because I bought it used, not necessarily because that's the ratio I was going for. Ever since I installed this setup it has struggled to do maybe 20 mph (no speedometer) with all highest gears selected. I just verified today that I am getting all gears in the C4 and moving between gears in the Atlas changes the possible speed, but not by much. I do have one ton axles and 40" tires, but that was no problem when I had the T18 and Dana 20. Also, 5.38 gears in the axles. I know, stupid low, but even with all that, gearing calculators say I should at 2,500 rpm at 55 mph with this setup, which is laughable knowing how much it is struggling to do around 20 which has me in the 3,000 to 4,000 rpm range.
Is there anything I could have done wrong installing the transmission that would allow it to shift, but not really allow it to go much faster? When I shift the Atlas, the speed difference is pretty small, not double or triple like it should be and not like I used to get between high and low in the Dana 20.
Any thoughts on what my problem might be?
