C4 Question
ol gray mare
I just installed the C4 after a rebuild. I did it myself with the assistance of the Bad Shoe video. I have a few hundred miles on it now. Everything works fine except full throttle shift from 2nd to 3rd. The engine revs a bit during the shift. Any suggestions as to a possible cause/remedy? Jim
Master Chief
Modulator valve adjustment. It's a tight area and I found the best tool to use is a short length of 10 gauge Romex house wire ... 12 gauge would probably work too. Strip one end and smash it flat so it resembles a straight slot screwdriver end. Then make a 90 degree bend about 1" back from that. Turn the modulator screw clockwise until it shifts where you like it but don't go crazy. A small adjustment, maybe 1/2 turn, is probably all you need.
Master Chief
Jim,
I just re-read your post and see that this is a 2-3 shift issue. My understanding is that the modulator controls 1-2 shift points while the servo and/or clutches control the 2-3.
Since you basically have a fresh build, I would inquire with a local transmission builder or reach out to Viperwolf on this site for his expert guidance on this.
Roger
Quick & Dirty
The 2-3 flare is the intermediate servo releasing before the direct clutch is applied. Check the intermediate band adjustment, then a teardown to check that the servo piston seal is good and the bore not worn, and verify/reduce the clearances on the direct clutch pack.
ol gray mare
ol gray mare
You are right Master Chief, it firmed the 1-2 shift. Nothing on 2-3. Next a band adjustment check!
ol gray mare
ol gray mare
It did need a band adjustment, it helped some. But not the cure I'd hoped for. Next check... servo.
pcf_mark
If you do end up taking it out check the end play before you take it apart. I rebuilt mine (the first time) and did not shim it correctly giving me to much end play and impacting shift firmness.
ol gray mare
ol gray mare
This took care of the flare that I was experiencing.
Wouldn't hesitate to do it again.
https://transgo.com/product-details/40-2/
I ordered that very kit from Summit last night. In retrospect, I remember the valve body I used was one I got on ebay. There was some pitting on the internals and some of the springs didn't look like what was on the Bad Shoe video. I bought a trans for parts the other day, and will rebuild the valve body from it with the Transgo kit. I'll check the servo while I have the pan off. Hope it works! PFC Mark, I searched the problem on this site and read your thread. Lots of good info there.
jckkys
The vacuum modulator regulates part throttle shifts along with the governor, The kick down lever effects full throttle shifts. Neither would cause or cure the 2-3 shift flair.
