pcf_mark
- Joined
- Jun 11, 2010
- Messages
- 3,696
I just wrapped up my 3 speed to C4 swap and the transmission is toast. I had a 50/50 chance because it was used with no history but at least I got almost all the swap problems out of the way. Except the Lokar shifter which I think sucks for $200!
Clean fluid at the top of the full mark. In drive it will not move at all no matter how high you rev it. In reverse if you rev the engine it will slowly drift back. If I put it in 1st or 2nd manually it still does not move forward.
Time for a rebuild! I was looking at BulkPart.com because someone here made a recommendation. I have done a few other A/Ts in the past and ViperWolf provided the manual so I am going to get after it.
Here is what I plan to get, please let me know what else I should add:
Master kit - overhaul kit, friction plates, steels
Front and rear bands
Filter and gasket
Should I add a TransGo shift improver kit and/or follow the tech page on C4 durabilty improvements?
Crazy guy taking out the trans he just put in...
Filter and gasket
