Borinqua Bronco
- Joined
- Dec 31, 2016
- Messages
- 64
Hello everyone,
I am looking for some advise about transmissions and ideas of how screwed I am. I have a '74 302 automatic and it's having problems shifting. For the last month or so when I start it up and haven't driven for a few hours (definitely if sitting overnight) I can shift from Park to Drive and there is no change in RPM or sound and the transmission fails to shift to Drive regardless of how long I let it sit. (I let it sit for 2 full minutes today before typing this message) If on the other hand I start up the Bronco and shift from Park to 2nd it will shift directly to 2nd gear. I am then able to move it up to Drive and continue my drive to work. Any ideas? The fluid is full and clean. No other maintenance done recently. If I drive around for 10 -15 mins, to the gas station for example, I can shut the engine off, get my gas and when i start back up it will shift into Drive with no problem. Generally if it doesn't sit for longer than 2-3 hours it will work as advertised.
Thanks for your help.
