C4 shuttles between 1st and 2nd
jckkys
I recall Viper describing a problem with the governor that causes the C4 to shuttle between 1st and 2nd. With mine this happens at low speed with light throttle, as in maneuvering in a parking lot. I can't find that thread or any other dealing with this problem.
Viperwolf1
electron whisperer
Here you go.
J
jckkys
To understand, is the governor spring weakened requiring the valve to be lightened up? Stretching the spring and removing weight from the primary valve seem to be doing the same thing. Is there a danger of over doing it? There's a lot of labor involved in redoing it after installation. I'd rather not. Also, with as much as this valve moves in the bore, does it create a ridge in the bore?
fishinman78
@Viperwolf1 I've been trouble shooting a 1-2 shuttle shift. The post describes pretty much exactly what I have going on. Transmission recently rebuilt. Shifts great under normal conditions but in a parking lot or slow moving with light throttle (parade) in drive it bumps back and forth from 1-2.
I've pulled the governor and cleaned it.
Just confirming I'm supposed to grind the spot in red off of the large valve.
Also am I stretching the spring 25% as well??
Viperwolf1
electron whisperer
Looks good. I would grind the valve and leave the spring as is.
rydog1130
where is this valve located? can it be removed without taking the trans out/apart?
