Hello,
I’m looking for help diagnosing a Ford C4 transmission in my Early Bronco.
The transmission has been rebuilt with new bands, a new forward clutch pack, new seals, an aftermarket servo, a new vacuum modulator, and a shift kit. I’ve also tried multiple valve bodies and replaced the governor.
The main symptom is:
Additional information:
- Manual 1 works normally when the transmission is first started.
- If I drive the vehicle in Drive and then shift back into Manual 1, the engine revs but the vehicle barely moves.
- Reverse remains strong and engages immediately.
- If I let the transmission sit in Neutral or park for a few minutes, Manual 1 will work normally for a 50 or so feet then “lock up”
- Disconnecting the vacuum modulator had no effect on the symptom.
- The governor appears to move freely.
- The valves in the valve body were inspected and appeared to move freely as well.
- Reverse is consistently strong.
- The issue only develops after the transmission has been driven in Drive.
