Material is 1.75" .120 wall cold rolled ERW. Bender is a ProTools 105HD, I also purchased their whiz bang notcher too.
Plans call for:
a spreader at the bottom on the B hoop for the lap belt mounting point, and shoulder belt mounts up on top of B (4 pt RCI harnesses)
an "X" brace across the B
spreaders from the B to kickers just under the bed rails
perhaps a bolt in spreader between the kickers just below tailgate height
A pillars from B over head through the dash and down just inside the kick panels, following the windshield real tight
spreaders between the A's up top and at dash height
overhead spreaders between A and B in a Y shape
frame tie-ins at the bottom of the A, B and C tubes
Basically a hybrid of Crab (prerunner, bent B hoop) and Dusty's designs (thru dash)
Hopefully when the A tubes are in it the B hoop will look less swoopy... the A's scare me, from a bending perspective, I did the B and kickers with just math, the A's I will draw out on the floor al la Pirate4x4 "bending 101"...
Still a lot of math and bending to do, but so far no real wasted tube other than about 15" extra for the down radius' (2x 7.25") on the B hoop that I didn't figure into my calculations, but I did accoutn for across the top
![Stick out tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
.... This is my 3rd cage...
