Trevor,
After the test bend I considered trying to get it in tighter to the floor with a deeper bends and less space between them, but then I realized that we wouldn't be able to get the TIG torch in between the spreader and footplate if I fit it too tight... A consistent reminder from my brother who is doing the 100 TIG welds..
![Stick out tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
And where it lands on the B hoop it makes a nice node...
But I will check and see how much more room I get by dropping them and welding them to the floor plate.
I will recess the seat mounts somehow... Either by bending the cross bars at the ends a bit or dropping the seat mounting points deeper... play it by ear...
From my overhead and dash spreaders I know that 16 degrees will get me one tube diameter off using 1.75", so around 30 degrees should drop me just over 3" which will get the seats close to the floor... So if I cope angle to sit on the tube and mount it facing down I should be in the ballpark.
If I recall I also put a couple inches of drop front to rear in the seat mounts I built for the floorpan, to get the seats feeling "right". So I might do that with the angle seat brackets, or by not bending the front crossbar.
I am trying to re-use the factory sliders for the drivers, that complicates things a bit, but I am cheap where I have existing parts that work I recycle 'em.
