old 71
- Joined
- May 11, 2013
- Messages
- 161
I have recently put new door skins on using 3m body adhesive , my question is I need to weld ( bead ) the bottom of my door to make it straight . I have already sanded the ends as much as I can without separating the skin. Can I weld on the pinch seam without messing up the epoxy ?
I know heat is used to remove an epoxied panel , if it cools down does the epoxy have the same strength or does it turn into something I don't want after heat has been applied ?
Thanks , Dale
Thanks , Dale
