bobtail
still trying to dial in on a cam change. i switched a stock cam for an rv cam. i thought it would be a three day job. so far its been a month long event. i have learned a lot in the last two months. i started out knowing little about cams lifters 'springs and now i know little about cams lifters springs. so here is where i'm at. after leaning about some cams changing the firing order, mine is now the same as a 351 the tappets are quiet. it idles smoothly. when i drive it performance is poor. when i step on the gas slowly it does alright. when i step on the gas quickly it bogs down and wants to die shooting flames out of the carb. any hints about what i'm doing wrong. its a 302 w/ original motorcraft carb.
