67bondobronc
- Nov 14, 2002
- 867
Well, I got my EB running good enough to take it out on some test runs and of course I ran into another problem. DEATH WOBBLE and shaking like crazy. I did the alignment check that is on BC's tech page and that I have it close but when looking at the front of my EB I can see that the knuckles are slanted in a lot at the top (am I correct in saying this is the camber that is off??). I also probably need to replace my track bar bushings but I think the main problem is the knuckles being slanted in at the top. It is so far off that it is noticeable. I have a D30 with the Ch*vy disk brake conversion with 33's and a stock lift.
I searched here and found out that I probably need shims to correct this problem and I should take it to an alignment shop to get this done. Most of the post I have found are about the knuckles pointed in towards the bottom and not the top.
Now this is a problem because I do not trust the EB (due to the shaking) to drive it the 15 miles needed to get to a good alignment shop and I have an explorer so I can't rent a trailer from U-haul. Any ideas on what I need to do to get this corrected enough to get it where it is safer to drive to an alignment shop?
thanks for the help
thanks for the help
