The passenger side headlight is aimed significantly lower than the driver side, but the driver side could also benefit from being aimed a little higher as well.
I have removed the buckets, tried bending the tabs, added some sticky felt shims to the grille at the bottom to try and raise the buckets, nothing seems to work.
Even with the “shims”, I can drive the top adjustment screw all of the way in (to the point of bending the adjustment tab inwards), and the aim stays exactly the same.
Is the spring tension too tight? Or is something else going on?
I’m about to just order new buckets.
The headlights are JW speaker LED.
