TXBronco 67
Stock rebuilt 302 with edelbrock 1406 600cfm carb and a manual fuel pump. The issue is after it sits for a few days, I can't get it to start without pulling the fuel line at the carb. I have an inline glass filter before the carb so it's getting fuel. So I crank it over a bit, then pull the fuel line off and it has pressure on it. A small amount of fuel comes out of the fitting, hook line back up and it starts right up. There doesn't appear to be any blockage or anything, so the only thing I can think is air in the line is causing the issue because the fuel seems to be draining back past the pump. Any ideas?
