Noticed exhaust seems to have really strong smell. I've heard of a carb running "rich"before like too much gas and wondering if I need adjusting. Tried small screws on side but no difference. Need some feedback on proper way to adjust.
care to elaborate?fix your exhaust
I'll chime in again. Pretty sure ransil is referring to the place your exhaust tip(s) exit the rear. BEEEEG problem on Broncos, aerodynamically speaking.
I was asking for the other details pretty much to find out the same thing, and if what you were experiencing might be related.
Broncos have sucky aero, and the exhaust exit is critical and a very narrow window. Turn-downs are a no-no. Exiting ahead of the rear tire is a no-no. Even dual exhausts is sketchy at best, and the single best place to exit the exhaust is behind the passenger tire angled out to the side, or slightly to the rear. NEVER straight out the back.
Any of that apply to you?
Turn downs when exiting side behind tire is a no-no? I did not know that. Is that because it splashes to rear and gets sucked up and in?
No, I was referring to the generic "turn-down" where they simple terminate the exhaust tubing right at the back of the muffler under the truck. Just aim it at the ground about the area below the back seat. Not a good idea on most EB's.
Some do it and don't have much to complain about. Even Johnny here at WH has that I think. But his EFI runs really well, and his rear window is rarely open unless the top or sides are off, so lots of fresh air in the mix anyway.
Turning the tip downward after exiting the rear is not a bad idea in fact.
Might even work better in some cases than a simple side exit.
