- Feb 29, 2024
- 83
Still playing with my carb on my BP 347. Came with a Holley 670 Brawler 4 corner carb. No experience with the 4 corner setup at all. Issue I am having is I have a stumble under load right off very light throttle. It easily pushes through it but it bothers me enough to try to get rid of it. Its amplified when its cold until it gets some heat in it. Originally it was pig rich at idle to the point it would foul plugs fairly quickly at idle. Off idle it actually ran fairly clean. I took it to the local "performance" shop to see what they could do with it and was alittle dissapointed with the result. They cleaned up the idle but that slight hesitation was still there under load as well as in neutral if you stab the throttle off idle quickly it goes bahhhhhhhwaaaaaa if that makes sense.
They did the following changes: Drilled primary blades 3/32" and set mixture screws at 1/2 out in rear and 3/4 out in front. Unhooked vac advance, light springs in so I had full timing by about 15-1700 rpms. Intial set at 18 and total at 36. No pinging at all but seemed odd to just disconnect vac advance.
I have tried various changes in timing and idle to try to get rid of that slight hesitation. In order to completely get rid of that bog I end up having my mixtures screws out at 3/4 rear and 1 in the front with the vac advance hooked back up. This made the engine way to rich again at idle but that transition off idle was perfect. I have verified I do not have the primary blades open to far as well as checked my accelerator pump adjustment. Float levels are correct as well as fuel pressure. Not sure what to try next. I have read about issues like this running air gap intakes and cold weather. Right now low is about 15* and high in the mid 20's. Temp is staying right around 175-180 while driving. Any help on this is really appreciated. Its my wifes daily driver so I really need to make it so she can bump the key, fire off and idle for a length of time so its not fouling plugs or stalling as well as just be as smooth as possible. Aside from the off idle stumble it really runs strong. It will melt the 33's fairly easily, just cant shift to quickly with the np435 lol.
Current setup is this and still have that slight stumble.
Timing. Initial 18* with total 36*. Vacuum advance hooked up to ported with 1 heavy 1 light spring so all in at 2800 rpms.
Carb. rear out 1/2 front out 1 1/4 secondary idle screw out 1/4 turn from where it was.
Engine specs are as follows as well as carb specs:
Carb specs from holleys site:
Description:
- Horsepower & Torque: 415 Horsepower / 415 FT. LBS. Torque
- Compression Ratio: 10.0:1
- Aluminum Heads
- Cast Crankshaft
- Hydraulic Roller Cam
Block:
- BluePrint Engines High Strength Cast Iron Block
- Increased Deck Thickness and Strength Webbing
- Priority Main Oiling
- 4.000" Bore
- 4-Bolt Main
- 1-Piece Rear Main Seal
- Improved Water Jacket Design
Rotating Assembly:
- Cast Crankshaft
- 3.400" Stroke
- Forged 5.400" Connecting Rods
- Forged Pistons
- 28oz Externally Balanced Front and Rear
Cylinder Heads:
- BluePrint Aluminum Cylinder Heads - HP9009
- 60cc Chamber
- 2.02" Intake / 1.60" Exhaust Valves
- 190cc Intake / 60cc Exhaust Runners
Cam Specs:
- .543 Intake / .554 Exhaust Lift
- 218 Intake / 226 Exhaust Duration
- @.050-112 Degree Lobe Separation
Ignition Timing:
- 10-16 Degrees Initial, 32-34 Total
Barrel Quantity | 4 |
Barrels | 4 |
Billet Color | Diecast- No billet |
Body Color | Polished |
Body Finish | Polished |
Booster | Down Leg |
Booster Design | Downleg |
Brand | Brawler |
Carburetor Use | Street |
CFM | 670 |
Choke | Electric |
Circuit | 2 |
Condition | New |
Cubic Feet Per Minute Rating | 670 |
Emission Code | 3 |
Finish | Shiny |
Fuel | Gasoline |
Fuel Inlet | Dual |
Fuel System | Carbureted |
Grade Type | Performance |
High Speed Air Bleed | 28/28 |
Idle Air Bleed Size | 70;70 |
Linkage Attached | Yes |
Marine Use | No |
Material | Aluminum |
Model | Brawler Diecast |
Primary Main Jet | 70 |
Primary Power Valve | 6.5 |
Primary Pump Nozzle Size | 31 |
Primary Venturii Size | 1.300" |
Product Type | Carburetor |
Sale Category | Carburetors and Components |
Secondaries | Vacuum |
Secondary Barrel Type | Vacuum |
Secondary Main Jet | 74 |
Secondary Venturii Size | 1.300" |
Supercharged Application | No |
Throttle Bore | 1 11/16" |
Warranty | Limited 90 Day |
UPC | 090127003657 |
Part Number | BR-67256 |
