I need to set my ignition timing after replacing the whole ignition system.
However the carb is also in bad shape, as it has been sitting a long time, and I'm pretty sure needs a complete tear-down. Holley, ~90% sure 4160 based on looking at lots of pictures.
anyway - I am assuming that I should set the timing first, then rebuild the carb right? Its close enough that it runs but it's rough.. but not sure how much is carb vs timing.
Or is there some reason I should do carb first?
