ECT port is in teh cooling tubes, Temp gauge port is in Drivers side front coolant cross over.
Large rear port is for PCV, metal screen drops in, followed by rubber grommet (Ford-best fit or Dorman help line-not the best fit) and finally PCV valve pushes into the center of the grommet.
ACT port on the mustangs was a on #5 lower runner, a boss on the manifold that was threaded. The earlier Explorer manifold castings may have had a boss, (thicker material) to thread on in. It was suggested in an earlier post that you could relocated the ACT to the inlet tube like the explorer does, it is much smaller that the Mustang one, pushes into the rubber tube.
