Catalyst protection temperature sensor
gws34
Does anyone have a wiring diagram or know how the Catalyst protection sensor in the air cleaner and the Vacuum solenoid that is part of the Thermactor system hook up? This is for a 1975 302 with manual trans. Trying to get this hooked up to pass emissions testing.
Also does anyone know where to get the Catalyst protection sensor? Been looking online, ebay and places like that. Auto parts stores look at me like I have 2 heads when I ask for these parts.
There is so little info out there to what these systems are are were for that year. I have the full set of 1975 shop manuals for the bronco and still can not find this info.
Thanks for any help.
Glen
Wrightracing
Just an FYI, you don't have to smog a 1975 and older in California.
Sent from my SM-N960U using Tapatalk
G
gws34
Sorry I am in AZ and we do need to do smog here. They go back to 68 for emissions testing here.
Trust me I hate trying to track down all of these parts that the PO removed, no one makes the new parts but I am required to have them on my vehicle.
I think if no one sells the parts it should not be required. Just my personal opinion
G
gws34
I found this phot from an old post from samD (i have just now emailed him to see if he still has there wires and parts)
If anyone knows how the wiring goes from the Catalyst protection sensor in the air cleaner to the solenoid. I have enlarged this photo but they go into a jumble and can not see everything completely.
If anyone has these parts they removed and want to sell or still have them on the vehicle that could give me the info it would be greatly appreciated.
thanks
Glen
Ovalis
Los Angeles
That was one year only in 1975, then they went to vacuum operated vs electrically. I can't remember if I have the wiring diagram at the moment but do you have the rest of the parts? In the picture, the wiring from that sensor goes to a vacuum solenoid valve mounted to the front of the drivers side valve cover. That solenoid valve controls the dumping of air from the air pump. Also tied into the circuit is a one year only electrical PVS (ported valve switch) valve that is screwed into the thermostat housing.
Maybe try searching the mustang 2 in 1975 or maybe other 302 fords in california. Maybe econoline we share allot of parts with them.
G
gws34
Yes I have been buying the parts as I find them. I have the PVS with the electrical connection on it. I bought a solenoid valve that should be correct and I have what I think is most of the parts. I know I am missing the sensor i mentioned and I have not been able to find the wiring diagram for these parts that are only set up for 1975. Next Bronco WILL NOT be a 75 this has taken me years to get these parts together and I feel like I am close but not quite there.
At this point if I had the money it would have been easier to do a coyote conversion than trying to get stock emissions stuff that was for 1 year only.
after the smog test these parts should be packed away in hermetically sealed packaging. i thought in AZ you can register as Historic vehicle and get around this crap. I get to look forward to this crap as when i retire we are moving out of hell to AZ but to Mohave county which has lesser restrictions.
what parts you missing now? do you know the ford part numbers for them?
for the odd stuff check the 1976 books as ford was always late publishing updated changes. ford use to have emission specific manuals but they are so rare you never see them.
Ovalis
Los Angeles
I'll see if I can find any wiring diagrams this weekend.
I'm pretty sure I have an NOS air cleaner sensor. Everything is in my storage unit and I'll dig through the boxes this weekend.
Do you have any of the wiring already? That is a unique connector for that sensor, but you can always wire it without a connector to make it work. In regards to the solenoid valve, keep in mind there are 2 types, normally closed & normally open. I forget which one is used in this application, but at this point for you I think you just need to pass a visual inspection vs it actually working correctly.
G
gws34
Thank you all for your help.
Rustytruck-
A historic vehicle has limits on how much mileage you can put on it each year, this will be my daily driver.
I do not know the part number just what it is called in the manual, if someone knows the number it would help, still trying to research that.
I have never seen one of those emission manuals, I will add it to my search of extremely hard things to find for this project.
Ovalis-
Thank you for looking for the part for me. Unfortunately I do not have the wiring. Getting info from many people , It was not until recently that I found out that 1975 was its own special year. I do not have any of the wiring or connectors. Again just got the PVS with the electrical connection on top and it looks like 'I can use spade terminals to make it work. The solenoid will arrive in the next few days, I was able to track down a part number for that so I believe it is correct.The only clue I have about wiring is the photo I have included in this post.
Once I get done with this whole emissions thing I will post all of my findings, part numbers, and wiring diagrams.
I am too deep in this bronco to just get rid of it and get a different year, so I plan on running the full emissions set up, since it was designed that way. Even though I still believe if you can not purchase new parts to replace worn out parts, how can a state regulate that you have to have this stuff. But that is a fight for another day. I just want to get this thing on the road and start enjoying it.
G
gws34
So I discovered something else, I do not believe it is a 1975 engine in this truck. I have to pull the starter and read the code this weekend but I just discovered that the distributor is not from this year so now I am adding it all up that this motor in not original.
Again to deep into it now, but if anyone has these last few parts I am looking for I am interested in buying them. Thanks for the help everyone!
Ovalis
Los Angeles
That ebay part is the exact part you are looking for. I searched for mine but was not able to find it yet. You should pick that up.
Here is the electrical diagram for it.
There should be Red/Yellow wire that supplies 12volts coming from the firewall like the the one that powers the carburetor solenoid. It goes to the Distributor Modulator Valve (the part that is bolted to the driver side valve cover). From that valve it splits to the Distributor Modulator Ambient Switch (this is the ebay part that is in your air cleaner) and also to the Distributor Vacuum Control Valve (this is the switch screwed into the thermostat housing). Both of those Ground at G-207 which is at the drivers side valve cover.
G
gws34
Thank you both! I will order and look at the wiring this weekend. Everyone on this website ROCKS! thank you again for your help
