Chuck, got more info on the heim stud? Do the knuckles still get drilled out and this is to keep threads out of the knuckle or does this fit in the stock taper or chevy taper?
The tapered end of the heim stud is the same taper as the F-150 so if you have the f-150 or 78-79 bronco knuckles and you want to go tierod under they will fit as is. If you have the 76-77 EB knuckles you will need to REAM(not drill) but the studs will fit over or under without added bushings. For all of the other EBs you will need to ream over or under. If you want to go over with any knuckles except the 76-77 knuckles you will need to use the TRO bushings. The TRO bushings will also repair the 3/4" bolt hole back to the f-150 tapered hole.
I became a member about a month ago. and have been wanting to be a contributor, just havnt done it yet. so i guess my question is if i become one before the dead line can i still get in on the chance for this? If not it totally understandable. But you dont get if you dont ask. Thanx a bunch.
