A big thanks to Dusty at West Coast Broncos for sponsoring another ClassicBroncos giveaway!
Prize: 28-Quart JPCooler
Description: (From the West Coast Broncos site)
JP Cooler is the ultimate ice chest for your off-road vehicle! Durable and soft-sided for use in irregular spaces, these coolers are designed and built especially for the trail, and for use in the parched desert southwest where coolers are tested to their limits! The 56-quart JPCooler is as large as a regular sized hard ice chest. It can hold two (2) cases of canned beverages plus ice!
Designed to Fit in YOUR Rig!
The 56-quart JPCooler measures 35" long, 7" wide and 15" deep. These dimensions are long and narrow, making it perfect for fitting among your gear, back seat, spare parts and tools. The 28-quart JPCooler measures 16" long, 7" wide and 15" deep. In a trail-ready rig, space is often at a premium, and the JPCooler is designed to take advantage of these space limitations while providing maximum cold storage space.
Heavy Duty Construction
This soft-sided, flexible cooler are ruggedly constructed using heavy duty 720D nylon canvas, with a steel-roller embossed PVC bottom. It has sturdy straps that wrap around for extra strength, padded carrying handles on the top and sides, heavy duty zippers, and an expandable cargo cord on top. The interior lining is guaranteed not to leak as long as it is not punctured.
Built To Perform
This cooler has been tested on the trails in the desert southwest in the dead of Summer! With outside temperatures reaching 123°F, with an average of 117°F and vehicle interiors reaching 198°F, the desert provides the ultimate proving ground for cooler performance. And the JPCooler passes the test with flying colors. You can't beat the quality, durability, and utility of these coolers! With the cooler full of ice we've performed tests with temperatures never falling below 100°F for 48 consecutive hours. After 48 hours we had just over half of the ice remaining. Your results will vary depending on what is placed in the cooler how much ice is used and how full the cooler is loaded.
Many Different Uses
Each JPCooler comes with a removable internal utility bag. The purpose of the internal bag is for use with sharp objects such as knives, forks or tools so these don't puncture the interior liner of the cooler and cause a leak. The handles make it easy to remove and carry with you.
The Rules:
Who can enter? - This giveaway will open to forum Contributors only as a way of saying thanks for helping support the site.
How do you enter? - Please post in this thread if you want to be in the drawing. That way only those that actually need the parts will be picked.
Deadline? - The winner will be drawn randomly. Deadline to enter is Fri May 16th (all entries in by 8:00 PM)
Good luck! And thanks again to West Coast Broncos!
Built To Perform
Many Different Uses
The Rules:
