Centech Horn?
TexasBronco
Waterford, MI
After passing the wires through i noticed both sides have a wire called "horn" and grounds. Does this mean i can wire in 2 horns? Also the rubber plugs keep falling out of the firewall. There was a post on this a week ago, but since is a 2 part question I asked it again. What can I use to keep them in place?
JTCamp
Austin, Texas
I don't have my horn hooked up, but you can hook up 2 horns if you wish...I would ask Centech about what your options are. <br><br> The rubber plugs are a pain. I've never had good luck with mine. Maybe someone here knows.<br>
rflud
Modesto, CA
Here's the deal - <br><br>Yes you can wire up two horns. My EB actually has two but stock I believe it only had one on the driver side. Currently I just wired up the stock horn.<br><br>I had the same trouble with the Centech rubber grommets falling out of the firewall. I tried all kinds of things to get them to stay. Finally (after a suggestion when I asked the same question on the forum) I cut the old rubber grommets from the original harnes and placed them on the Centech harness. It now seats in the firewall like it should. I used some black silicone to seal the cut I had to put in the grommet to get it around the new harness. It looks fine and fits great.<br><br>Good luck.
LSUpete
I saved my original grommets and just cut the Centech grommets off. Then wrapped the old grommet around the wires and used a bonding agent for rubber to secure the grommets back together.
