centering front-end, trac bar
Whoaa
For some reason I'm just drawing a blank right now, too many things on my mind to work on tommorow; springs, radius arms, correct mounting postion for shock hoops, and so on....
Once again I'm drawing a blank on information I have read before...
When going up 5 1/2" with suspension lift on these old Bronco's, typically they offset to which side, drivers side or passenger side?
My goal is to center the front diff between the body? Frame?
Take some outside measurments from the wheels/tires? Get both sides the same distance and then secure the adjustable trac bar?
I'm ready to install one that has some adjustment http://www.wildhorses4x4.com/product/Adjustable_Trac_Bar
Tips, experience and advice to getting it dialed in properly? Thanks!
yakelys69
As the axle drops it shifts to the driver side, as it raises it shifts to the passenger side. I marked the center of the axle and center of the front frame cross member. Estimated ride height raised the axle to that height without springs and set my trac bar length. I only disconnect the track bar with springs out.
savage
Bronco Nut
Renton
I've never tried it with the springs off. The ride height will change as the springs settle, so I get it close,with the springs on, I do mark the center of the cross member, using a plumb bob or a string with a large nut on it, hanging down, and then mark the center of the axle. Then recheck it ones the springs settle. To get the hole to line up with the bracket on the frame, just have some one in the bronco turn the steering wheel, the direction you want the axle to move, when the wheels are on the ground.
01Dudley
Knoxville
I usually keep this very simple. Put the front axle on jack stands so the wheels are just off the ground. Make sure the wheels are straight. Pic a point on the top of the tire, use a straight edge on the outside of the tire, or just a spot on the tire you know is in the same location on both sides. Now measure straight in to the top of the coil. You want that measurement to be the same on both sides. Do the math and figure out how far lf to rt the axle needs to move. Disconnect the track bar at the frame, adjust it and reinstall. You can easily move the body back and forth by hand to reinstall the track bar.
rednck21
I stand in front of the bronco and eyeball how far each tire sticks out past the fender on each side and adjust the track bar as needed. Been doing it that way for years...
Whoaa
Whoaa
Thanks guys! I pulled measurments from various places to double/triple ck my accuracy and now have the frame center marked as well as the center of the diff housing. Trac bar installed, for now its just pretty close.
And I re-learned the importance of mocking everything up [the hard way] before final welding. Using the Duffy long Radius arms, and a WH trac bar riser -mounted to the old mount, I discovered that the angle is wrong and the riser is tipped to far back not allowing a correct fit for the trac bar. The alingment from the frame trac bar mount to the diff riser mount is off. Because I didn't have the forethought to ck everything, and then double ck everything for proper fit, now I get to cut the new riser mount off, and then weld it back on in the proper place.
Once I get it a little closer to rolling I can make the final adjustments. And I still have a little work to finish to get the tie-rod & drag link ready to install on the top of the knuckles
thegreatjustino
Red Head Grease Monkey
Stockton, CA
Set everything up, tires on, everything installed, tires on, sitting on the ground as you'd drive it. Now disconnect the trac bar. Turning the steering wheel will move the body back and forth over the front axle. When it's centered where you want it, have someone hold or somehow chock the steering wheel and install your track bar.
twisted 66
Norcal-Tracy
X2....I have also seen the same thing done but with the wheels off and axle on stands while using WMS as a reference. Just have good stands...
yakelys69
I don't have much experience on this, just asking a question. Assuming those are soft-springs, long-arms with heims and coil buckets that allow the spring to pivot. With no drag-link and no shocks, once the track-bar is removed is it possible for those springs to buckle (axle to spit out to one side) if the body is shifted or bounces?
Whoaa
Whoaa
^....NO.
They are soft springs, and they can and will flex and bulge a little during use. These are aftermarket, progressive rate, springs which are made soft to produce a better ride. The lower spring retainer in this pic is a heavy duty aftermarket cup, but the original ones work similar -the lower part of the spring coil is rotated into the cup during installation which keeps it in place. The upper part of the coil is held in place w/ a small bracket that bolts to the coil tower.
rguest3
The Trac Bar setting may be close now, but once you get all the drivetrain and everything else completely installed, then adjust the Trac Bar to it's correct length.
savage
Bronco Nut
Renton
X-2 on track bar adjusting will have to be redone once the bronco is complete. So I would not worry about any adjustments to the track bar or tie rods, you can get them close, but you will have to redo them.
What they said Whoaa. And if you haven't already, I would not spend any time cutting it back off yet either. It might be right on the money as it sits.
About the only way I can think to do it at this stage in the game would be to support the frame, remove the springs and adjust the axle to the expected ride height for your setup.
If running a 3.5" lift for instance, the distance from the bottom of the frame rail to the top of the axle tube would be 10.5" or so. Moving the axle up and down will effectively twist the lower mount, so that angle is just as susceptible to ride height as the upper mount angle is.
I suppose you could devise a way to compress the suspension to it's expected ride-height too, but not sure if that would be easier for you or not.
Banjer Picker
^....NO.
Sorry for the thread jack but when you installed your passenger side lower spring retainer did you have to grind/clearance your track bar riser? Looks like it in the picture. I’m installing the same spring cups right now and they don’t fir with my track bar riser right there.
1badd73
I used plum bobs to center my front axle. I taped one to each side of the front fenders and centered it that way.
