Centering the front axle
jamesonfd
I'm installing a new tie rod and adjustable drag link. I recently installed a Dana 44 to replace the old 30. I noticed that the axle is about 1" to the passenger's side; springs seem to "drift", and the tires are unequal in line with the body.
My first inclination is to remove the trac bar (i have a new adjustable to replace), and rig a come-along to pull the axle into position while raised; adjust the new trac bar to length and install.
Any thoughts on this procedure, or a better way?
Many thanks in advance.
broncnaz
That will work just fine. If you have a helper and your steering is still hooked up you could have them just turn the steering wheel and hold it where you want it then install the track bar.
JSBX
The procedure you describe is how I do it but instead of using a com a long I use a medium to large size turnbuckle with some small chain. You can be more precise when lining up your body with the frame and it is more compact and easier to operate. Some times that one more click on a come a long is to much.
thegreatjustino
Red Head Grease Monkey
Stockton, CA
All four wheels on the ground, trac bar disconnected, steering linkage hooked up. Turn the steering wheel to center the chassis over the front axle. Have someone hold the steering wheel or use something to hold it in place, install the trac bar.
It's a hell of a lot easier to use the steering wheel to move the chassis than trying to move the front axle to center with a come along.
J
jamesonfd
Many thanks to all. Good input. Very much appreciated. I'll post after it's done.
If this is a project vehicle without an engine (or body)…
Wait. As the suspension is loaded it will shift. That is how the track bar works.
If this is a running and driving Bronco and you are just dealing with an offset axle due to a lift, the adjustment will take care of that. Du everyone a favor and check thread engagement after you get the length you want. Easy to extend it to the last couple of threads and it holds, until you need it to hold and it doesn't.
J
jamesonfd
Piece of chain and a turnbuckle, worked like a champ. Far simpler and easier than I thought. For above, running and driving vehicle, lifted. Settled right in.
