There's nothing "plug-n-play" out of a yard for 351w with EFI. Other than a few Mustangs, which you'll never find anyway, and 93-95 Lightning PU's (pretty rare too). The 5.8's with EFI came with intakes that are way too tall (Saddleup withstanding) for EB's and run Speed Density computers that are unforgiving to changes. So, find a decent 351W/5.8l 1969-1996 (94-96 roller motors preferred) and buy an Edelbrock EFI manifold, 65mm throttle body, 80mm Lightning MAF, harness, injectors (19 or 24lbs), fuel rail, computer, HP pump and various sensors. Some of that stuff you can get in a yard, but other than fuel rails I'd buy new sensors and injectors and a RJM pre-made harness. There isn't an unmodified ECU that will correctly run a 5.8L. The Mustang (5.0) ECU's work, but the fuel tables will be off for 5.8L, so you'll need a TWEECER or custom tune. Everyone that I've talked to that is running an EFI 351w with a Mustang computer is either contemplating a TWEECER or custom ECU tune. I estimated in an earlier thread that $2000-2500 would be about the cost to convert a 351w to EFI and do it right.
I'm not trying to discourage anyone, but go in with both eyes open, especially if you have limited budget or limited time. I still think a complete 5.0 H.O swap from a Mustang or Explorer might give you the most bang for your buck and be the simplest road to go down.
For serpentine, most everyone is using Explorer or Mustang stuff, but I used an alternator bracket minus the smog pump from a early 90's F series and a PS/AC bracket from a 88-96 Van. The jury is still out for me on whether serpentine was worth the trouble.
