Check My Drum Rebuild
Okie69
First time I’ve attempted to rebuild drum brakes anyone see anything wrong before I move on?
SVTY SVN
LA/TX
Just did this for my first time also so am a noob. On my 77 at least, there was a flat, rectangular piece immediately to the right of the spring I circled in attached pic.
SVTY SVN
LA/TX
This pic is opposite side of vehicle but best pic I have of the piece I described above.
B RON CO
Statesville, NC
Hi, the installation looks good, you got the small primary shoe in front, and not all parking brake link bars have the metal plate that svnty svn mentioned. Remember to adjust the shoes and bleed the longest line first to the shortest line last. Any issues adjusting or bleeding the brakes, just ask. Good luck
Okie69
Okie69
Phew had me looking for that part of the spreader bar.
Getting close! Put the rest of the rearend together and bleed brakes and I can test drive it for the first time in 8 years!
ssray
South Central NE
I can see the R for right on the adjuster lever but can’t remember if they marked the adjusting screw as well. It’s been 40 years since I had a drum brake apart but the right side should be left hand thread and the left should be right hand thread. I was thinking it was possible to get them on the wrong sides but might be remembering it wrong so disregard if that‘s not possible. :unsure:
Scott
jamesroney
Fremont, CA
First time I’ve attempted.
The lower spring, (light blue one) looks like it's in the wrong hole. Is there any tension at all when the adjuster is fully closed?
All the one's I've seen have spring in the big hole. (next one up...) but your new spring kit might be different.
Did you take a pic before you took it apart?
Okie69
Okie69
Ope good catch. I do believe it is in the wrong hole. There was barely any tension on the adjuster when it was completely closed.
Rustytruck
were the backing plates under the brake shoes smooth and flat? they were supposed to be coated with brake grease as was the screw threads for the brake adjuster The adjusting cable where it goes around the pivot plate and the pivot stud assembly for the parking brake lever.
at one point on my bronco the shoe pads on my Bronco backing plates got severe groves and had to be welded and sanded flat again for the brake shoes to work properly.
