clutch problems--violent shaking
lowndes
Vermont
Maybe someone knows what's going on with my '68. Recently when I'm at a stop and I'm letting out the clutch, the truck vibrates really quickly and sounds a little like a machine gun. It hops as it's doing this very roughly and fast.
What's weird is it doesn't happen every time. Maybe every four or five times.
Anybody know what's up with that?
Thanks,
Larry
Skuzzlebutt
PhD, Dr. of Broncology
Honeymoon Bay
Clutch chatter. It's time to replace your clutch and resurface the flywheel. Don't do one without doing the other. Oil leaking onto the flywheel can be a contributor also. Loose motor or t-case mounts will make it worse, but not cause it.
lowndes
lowndes
Vermont
Damn! I was afraid of that. What do you think is the best way to go for a clutch , local autoparts or one of the online bronco sites?
Blue71
Definately sounds like clutch chatter. The Bronco 3sps were known for this. Do as Skuzzlebutt says and get the flywheel resurfaced too. I would also install a diaghram style clutch instead of going back with the stock style. The stock clutch has 3 fingers where as the diaghram style has more like 18 for the holding power. Good Luck,
Blue71
agent_orange_71
Bluefield, WV
While youre replacing the clutch, Id go ahead and replace the throw out bearing and the pilot bearing in the back of the crank. The old pilot bearings are just brass bushings whereas the new ones are roller bearings, meaning they last longer. Its cheap, and you really do not want to pull it all apart again when the pilot bearing goes.
velpoe
Cumberland, MD
I used to have clutch chatter too. Do as the others recommend, while you're in there, resurface the flywheel, and change the pilot and throw-out bearing. I went ahead and got the Centerforce II clutch. Some say it's worth it, some say it's not. There's alot of debate about that... Make sure your rear main seal is not leaking onto the clutch. If it is, you might as well drop the pan and replace that too. Good luck curing the problem. Oh yeah, I haven't had any chatter since I installed the NP435 either ;D .
j.r.nice
I battled clutch chatter for a year. Replaced the clutch with Centerforce II, resurfaced flywheel, throwout, pilot, trans input shaft bearing etc. STILL CHATTERED!! While I dont disagree with the previous advice, I would try the cheap - easy stuff first. (absent an obvious trail of oil into the bellhousing!
Check the "z" bar for wear on each end. If the holes are oblong (eggshaped) replace it. Replace all the nylon bushings. Check the pivot points (frame and engine) Make sure all of the pivot points from the pedal to the clutch are tight. Finally this is what solved mine.
Dont delay too long. The violent hammering on mine destroyed the roller bearings on the input shaft, which caused other damage.
wildbill
Old Bronco Guy
;D ;D ;D OLD time fix pull up to a tree ect and put bumper to tree and slide the cluch a little and sometimes that will fix for a wile. Also when you come off the line do it at about 3000 and it wont do it but is hard on tires good luck.:p :p :p Bill :cool: %) :p
jaydub01
Daytona Beach, FL
i have had chatter ever since i got my truck, replaced the clutch and flywheel, which helped a little bit but still chatter. It only seems to chatter now when the engine heats up, then the chatter is impossible to stop. Oil does leak from my bellhousing, so could this be the problem?
raleigh_bronco
If oil is leaking from the bellhousing, what's this caused by and what is the fix? I've got this problem also but no clutch chatter.
supermottl
Indian Harbour Bch,
I got my new clutch kit from JBG. It comes with all the crap you need, that was stated above. It's a LUK. and I like it. My clutch chatter wasn't bad, but now it's gone. While I had the tranny out, I did the rear main seal. pretty easy while the tranny isn't there. I also replaced tranny mounts and anything else in there...
feels like a new truck...
j.r.nice
generally when it's coming from the bellhousing, the rear main is going out. Take off the pan and replace it. In the old 289/302 it's a 2 piece seal. The original ones were rope, the replacements are rubber. A tool called a "sneaky pete" will pull the old rope ones pretty easily. Basically looks like a small cork screw. Available at most parts places.
It can come from a leaky front seal on the trans. bearing retainer. Pull the box and press out old and press in new. Cheap part, expensive to have done.
It can also look like the leak is from the bellhousing if the rear oil pan seal / gasket is leaking. The draft from under the truck can blow it back. Generally the block plate will keep it out of the bellhousing.
Again, not all chatter comes from the clutch disc itself. I would say it depends on the age/mileage usage. I put 2 (yes2) Centerforce assemblies in @ $300 a shot before I found mine in the linkage. Centerforce technies walked me through it until it was gone.
Now I have a chatter free EB with an AOD.
;D ;D ;D
J. R.
That sounds like classic clutch chatter, do a search, there is a lot already on this board about it. since it started quickly, look for something broken more then worn. Make sure the engine and trans mounts are good.
I knew of a jeep that was so rotted that it had clutch chatter because the body flexed.
The ultimate cure is going automatic.
