Clutch replacement
jhill52
How long for a skilled mechanic to R+R a clutch in a srock 71 Bronco.
Skilled in general, with most of the right equipment: Maybe 6 hours (if they don't run into too many of the "old Bronco" snags along the way).
Skilled specifically with older 4wd vehicles and ALL the right equipment: 4 hours.
Skilled and with many Broncos under their belt: 2 hours.
PS: those are just guesses on my part. Everyone's skill level varies, and that job would take me two days because I have to lie on my back and stare at stuff hoping it will remove itself and then I have to clean and paint everything before putting it back together.
But that's just me...
ngsd
I want to meet the guy that does it in 2 hours! He is my hero!
Mine too!
But I'm only going by what I've heard others claim.
blubuckaroo
Grease Monkey
Ridgefield WA
It really all depends on the equipment you have.
With a two or four post lift & an tranny jack, two hours easy.
I usually separate the tranny and transfer case, because I haven't got that stuff, work alone, and I'm a wiener. I can have it done by dinner.
mrdrnac
Paul that is exactly me also!
73azbronco
A week, because I would generally, always, remove the flywheel and reface it, that takes a week min, then install all the new parts with it. But time wise, I'd guess 2 to pull everything, hour to clean up, let it sit till flywheel is done, then then like Paul, I'd stare at all the stuff I hope would fix itself, decide which finger I am willing to sacrifice to the mechanic gods of torque busting, 2 to install, depending on beers, hangover level, et6.
Madgyver
Bronco Madman
I'll be doing this clutch swap soon but also contemplating if I should drop in that 393Clevor motor too at the same time. It's a driver and have been fighting shifting issues recently, Clutch has been adjusted to its max and now need to double clutch it sometimes to shift.
I'll time myself.
But my rig is not stock. No 2 post lift here. Just a driveway, rig on 37"s and 2 hydraulic jacks and a mad built transmission holder.
