Most of you cats probably know this. This is for those who don't, which was all of us once.
Clutch rod needs to be lengthened post body lift. Numerous options exist. This is the two heims plus all thread option. No welding req'd. One cut to all thread. Off the shelf standard parts.
From Mcmasters:
http://www.mcmaster.com/#6072k33/=dgants
http://www.mcmaster.com/#98805a031/=dganqh
End result:
Considerations:
From Mcmasters:
![ItemDetailScreenBallJointLinkageHeavyDutyFemale.gif](http://www.mcmaster.com/param/images/RodEnds/ItemDetailScreenBallJointLinkageHeavyDutyFemale.gif)
![93225right.gif](http://www.mcmaster.com/param/images/threadrodstud/93225right.gif)
End result:
![CIMG3775.jpg](http://i295.photobucket.com/albums/mm140/dalba4/Bronco/CIMG3775.jpg)
![CIMG3776.jpg](http://i295.photobucket.com/albums/mm140/dalba4/Bronco/CIMG3776.jpg)
Considerations:
- Use high thread per inch for better adjustment of length - 3/8-24 shown.
- Heim end with captive stud has two benefits - 1. No bolt to muck with 2. Has increased stand off from the linkages. I should have gotten two heim ends with captive studs.
- Alternately two heim ends without studs can be used but you'll want to space out the clutch and Z bar linkage connection, so this is more elegant. IE not using 3 washers.
- 3/8 is the orig clutch rod diameter so bushings can be re-used. 7/16 is the diameter you'd need if ditching bushings was desired.
- If you used mild steel all thread you could save couple more bucks.
