I'm having a VERY hard time getting through to BC. Not sure what the issue is.......I need some help on this. I'm not seeing the forest for all the damn trees I guess. Frustration has set in and that causes total blindness.
I've got BC's ZF Master Cylinder mounted in the Speed-O hole and I can't figure out the clutch rod. I've read to use the existing hole in the clutch pedal. Nope, not happening as it's WAY too high. Drilling a new hole isn't the issue....The rod lines up with the pedal so no issue there.
Clutch pedal travel is my issue. The MC bottoms out WAY before the pedal hits any kind of a stop. Before the switch I had both clutch and brake pedals level. I've adjusted my brake pedal down to what I keep finding is right. I'm reading I was a tad bit high before the swap. Even with lowering the brake and positioning the clutch at the same height, the clutch has too much travel.
What's everyone doing to resolve this? Adding a stopper to the pedal or just letting the MC bottom out as the stop? I suspect bottoming out would cause damage to the MC? I've tried every combination of rod length I can and frustration has set in. And why is the bolt they sent with the kit so DAMN long? Is it supposed to just be loose as a goose? I would need to lower the brake and clutch over 1 inch more to get CLOSE to not bottoming out the MC.
Please help,,,,,at this point pictures would really help because I'm starting to drink...more than I normally do......This is the last step to being on the road....so close but yet SO FAR AWAY
Tim
Tim
