Damn I work slow! It takes me forever to get anything done, it seems like. Anyhow I'm happy to report that my garage wiring project is now DONE ;D When last we left off, I had completed wiring the interior of the shop but I hadn't buried the lines out to the shop, so I only had one leg (no 220V) on a jimmy-rigged drop cord from the garage. So I couldn't use the lift, air compressor or welder. So the next step was to bury some lines and get everything properly hooked in to the feed from the main panel at the house.
Luckily a Clamper buddy of mine has a back-hoe so he came over and did the trenches for me. Where I live in Mentone, CA is an old riverbed and its pretty much just rocks and boulders, with a little bit of sand in between. So its a major PITA to dig any hole just to plant a tree or a fence post, let alone a hundred feet of trench. So I couldn't have done it without him.
I decided to use the opportunity to lay in some water pipes while I was at it. For the electrical conduit I had planned to do 1" but I got shamed into upping that to 2", mostly by Tom Doran and the guys on the So Cal Broncos list. I'm glad they did because I later found out that any smaller and it would have been really tough to pull the cable through.
I couldn't just push those boulders back in on top of my pipes, it would have crushed them so I ordered up a load of fill dirt to cover the lines with.
Then I had Billy come back over and finish up the tractor work. Fill sand over the pipes, then push as many of those rocks back in the hole as would fit, then smooth out with more fill sand.
I had my doubts with all them damn rocks but he was able to get it pretty smooth.
During the several weeks between laying the pipe and finally getting the trenches filled back in, I had pulled cable and made all of the final connections. I had to do some upgrades to the sub-panel in my garage that I pulled power from for the shop, as well as at the main panel at the house. But I finally got it all done and finally the shop is fully functional. First thing I had to try out the lift ;D
So hopefully the Coco's Mods thread can get back to Coco soon, now that I'm done with the shop upgrade detour.
