Combining 2 systems?
broncbusted
South Carolina
Is it possible to use the 91-2000 explorer serpentine front dress with the 93 Mustang EFI components? I have the 93 Mustang setup and the radiator to fan clearance is a problem so that's why I am asking. I am using a Ford Racing crate engine.
sykanr0ng
It is the system from 1996 to 2001 Explorer and Mercury Mountaineer with the V8 only that you need, the V6 set-up will not work.
There are some on here using the Explorer serpentine system with carburetor engines, so it should work for you.
B
broncbusted
South Carolina
Found One
Hey thanks for the replies. I found the parts today at the pull a part. I got the the fan,ac and bracket with the power steering pump. I have to go back tomorrow and get the alternator and bracket and the front timing cover and the harmonic pulley. I was really hot and I had to quit before I passed out!
Thanks for the correction on the years, I needed that!!
Thanks again
B
broncbusted
South Carolina
Ok Flywheel question?
The explorer balancer is 50 oz-in. Pre-'81 302s are 28 oz-in balance. You'll need to correct the explorer balancer to use it on an older 289, 302 or any 351W. Read the tech article: http://classicbroncos.com/forums/showthread.php?t=158868
Ok, I have the Ford Racing engine From Summit and the original C4 transmission in the 1976 Bronco. I remember something about the flywheel weight when I put the engine and transmission together with the 1993 Mustang front serpentine system but not sure about the flywheel weight? I am now going to replace the Mustang serp with the 1996 Explorer system and am wanting to make sure the flywheel is correct. Is there a way to easily determine the correct flywheel without tearing down the motor/ transmission?
I did stop working on the Bronco for a few years and my mind is not what it used to be and these changes are hard to keep up with at times so cut an old Bronco owner a break when replying.
