I've had these for abour 5 years. VERY stout. They help keep the rocks off the body and make a great pivot point. Hard to use a HL jack with though.
HTH
I don't imagine that it's very often. BUT... 'ya never know. Sometimes the front or rear is just not as convenient as the side when you're sitting on a pile of rocks.
Ok I am in for a set of capped. I had to go out and make sure I still had rocker panels to bolt to. Mine should have the flares and be painted by the time this buy ends so I should be able to get the measurements that you will need. Thanks,
Steve
GENREAL UPDATE!!
When November 1st comes around I'll email all intrested partys. At that time you can let me know if you want capped or uncapped Hanson rockers. If you want the capped rockers I'll send you a drawing to fill out.
Scott. Please add me to the list for a set of uncapped. Thanks!
Baja71. I'm pretty sure they bolt to the rocker panels inside and out. You can fab something to tie it to the frame though. I don't think it's needed unless you're going to get crazy. If you have an auxilary tank it will need to be removed to install. I'm keeping my steel auxilary tank so I'll be fabbing a skid plate that will tie to the frame. Someone please correct me if any of this info is bogus. :-[
