- Joined
- Jul 13, 2023
- Messages
- 489
The link is for the non GPS. Here is the GPS https://www.ebay.com/itm/2849004110...d=link&campid=5335857059&toolid=20001&mkevt=1Is that the link above or do you text seller?
I find it funny how it solves the same problem for a 5 year old engine and a 55 year old engine.Cant wait for the ebay site to list "Early Bronco" as a user...
I considered electric steering and brakes about a decade or more ago, no tech to support what I needed. I would and does solve a lot of front dress issues. Glad to see it evolve.
https://www.evcreate.com/wiring-the-tesla-ibooster/This is interesting. I am currently building another custom offset bracket for the HB different from my other builds. I may shift to this idea if its a 2 wire/3 wire thing.
Do you need brake sensors for this to work?
Is it just the mechanical rod to command the brake functions?
I like how HB is just the rod that commands fluid direction.
What are you trying to do with offset and the HB? The electric stuff is interesting, but I think my offset HB turned out beautifully.This is interesting. I am currently building another custom offset bracket for the HB different from my other builds. I may shift to this idea if its a 2 wire/3 wire thing.
In Dick’s picture above, only 12v constant, 12v ignition and ground have to be run. His colored lines show that you just have to run wires from one plug to the other. Set up that way, no sensors are required, it just boosts the mechanical rod connected to your regular brake pedal.This is interesting. I am currently building another custom offset bracket for the HB different from my other builds. I may shift to this idea if its a 2 wire/3 wire thing.
Full disclosure, this is second hand information I have not proven it myself.In Dick’s picture above, only 12v constant, 12v ignition and ground have to be run. His colored lines show that you just have to run wires from one plug to the other. Set up that way, no sensors are required, it just boosts the mechanical rod connected to your regular brake pedal.
From what I've read yes. I'm looking at doing hydro assist as well and was thinking running 3 systems might be asking a lot which is why I'm looking at electric brakes.Curious about the Volvo pump, does it have the pressure to run a stock PS box and 35's as well has hydroboost brakes?
please let us know what you find out about a 3 wire connection.Full disclosure, this is second hand information I have not proven it myself.
Finished my conversion to an electronic brake booster out of a Tesla. I used the Gen 1 iBooster. There is a good wedisite for all the info on the iBooster, its called evcrate. I had to use the angle braket off the firewall to make it fit with my 5.0 EFI swap.So I have a question for any knowledgeable souls out there. I have a 77 Bronco with a mid 90's Mustang 5.0 and a mustang hydro boost brake set up. I am wanting to convert to a Tesla electronic brake system using a bosch ibooster. So the question I have is about switching out the Master Cylinder. The one that comes with the ibooster has a 1 inch bore. I have disc front and rear and need a 1 1/8 inch bore Master Cylinder. I have a Welwood MC with a 1 1/8 inch bore. the mounting holes on the MC are oval so it will bolt up to the ibooster brake booster just fine. It just needs to be clocked about 45 degrees for the new MC to be level. The only other issue is that I need to fab a push pin for the booster push rod to make conatct with and be flush with the new Master Cylinder plunger. Does anyone see any flaws in the idea? I should be able to switch out the Master cylinder? Correct. All the Electric vehicle forums do not talk about switching out the MC.
Comments and feedback welcome.
As part of this I am also switching to a Volvo Electric Power Steering pump. But that is very straight forward.
thanks Fred C
