- Jun 13, 2012
- 804
notice today that i had a few drops of coolant on the floor right under the passengers front side. after a quick diagnose i found the the overflow bottle level is way below the cold fill line and the coolant seems to be leaking from the radiator cap.
looks to be slow dripping out from the underside of the cap, however not enough splatter on the frame/lower engine bay or underside of the truck to justify the amount of coolant loss from the overflow tank.
what could be causing this? a bad thermostat?
also are all OEM 289 V8 radiators the same throughout 66-77?
thanks
thanks
