Coolant Leak?
bostonbronconut
Question Asker
Wayland, MA
I got a nice surprise this morning when I started my Bronco. I'm 99.9% sure this is a coolant leak from this pipe connection but I don't want to start poking around and undoing stuff without checking here first.
I bought new pipe clamps and I will inspect the area for corrosion or cracks. Anything else I should consider?
Thank you for your help!
B RON CO
Statesville, NC
Hi, that is the heater core connection.
I would be very careful removing the hoses.
You do not want to damage the heater core by man handling the hoses which are probably stuck to the tubes.
I would cut the old hoses off with a razor blade and plan on replacing them.
Hopefully just the hoses are shot and the heater core is OK.
Be gentle.
Maybe it is time to change all the hoses.
Good luck
jedblake
Boulder City, NV
You can also find hoses with the molded 90* bend at your local auto parts store. They usually let you go in back and search out. Makes for a clean install
bostonbronconut
bostonbronconut
Question Asker
Wayland, MA
Be gentle.
Good luck
I cut/pulled the hose off and used my thumb to plug up the hole, which stopped the leak. I inspected the male piece (heater core connection) and it doesn't look to have any damage so my diagnosis is that the hose clamp was starting to get warped and the hose could use replacing.
rmk57
If the hose long enough, cut the end off and shove it back on with a new clamp.
B RON CO
Statesville, NC
Hi, pvtshaker caught an open vacuum port on the metal pipe behind the carb. The vacuum hose probably goes to the brake booster.
Do you have power brakes?
Do you have an automatic transmission? An automatic transmission needs vacuum to the modulater.
You also have some hose looping around the heater control cable. Post a better picture of that, from the divers side.
If you have a 3 speed stick shift just cap off the open vacuum port, and your idle will get better.
Good luck
bostonbronconut
bostonbronconut
Question Asker
Wayland, MA
Thank you for all the help thus far. When I got back to the bronco, all the coolant from the tank was empty. I replaced the hose and added new clamps and then filled up the tank with new coolant. When I tried to start the engine all I get is a ping sound and nothing else. I haven’t touched anything else in the engine compartment.
bostonbronconut
bostonbronconut
Question Asker
Wayland, MA
Here is another image from the other side with a closer look at the parts again.
gr8scott
Here's the open vacuum port they're talking about. Put a vacuum cap on there.
Also, is it just me, or does that coolant on the floor look a little thick and milky?
jckkys
You need the original 76-77 air cleaner. It brings in cool air through the core support and flows better and quieter than that el cheapo triangular thing. Ford had the heater hoses routed away from the exhaust manifolds/headers. The whole thing was designed by automotive engineers not a pin head that only cares about shiny bling to sell the truck to people who only see the bling and don't know what an EB engine compartment should like. The heater hoses are new and completely incorrect. Again a shallow attempt to create a cosmetic "look", not produce dependable truck. Here is a correct engine compartment.
https://bringatrailer.com/2015/03/04/27k-miles-mostly-original-1977-ford-bronco-302/
I would trust this Bronco on a cross country trip. Can't say that about the OP''s. It makes a lot of sense to return things to the original configuration, then do real improvements where and if needed.
bostonbronconut
bostonbronconut
Question Asker
Wayland, MA
Thank you for the feedback!
Re: Port - I'll get a cap on that immediately.
Re: Coolant - I wouldn't be surprised that the coolant hasn't been swapped out in a while. I added brand-new 50/50 coolant to the empty tank once it drained out.
bostonbronconut
bostonbronconut
Question Asker
Wayland, MA
Good luck
Re: Power Brakes - Yes, I do.
Re: Automatic Transmission - Yes, I do.
Re: Idle - I haven't had much of an issue with the idle; the truck not starting is the new issue. :mad:
bostonbronconut
bostonbronconut
Question Asker
Wayland, MA
Re: Edelbrock Air Cleaner - I'm the pinhead who installed it. I replaced the carb a few weeks ago and I wanted to match the carb with the air cleaner for a solid fit. I do have the original air cleaner but it does not have any of the duct work that your example has. I haven't had any issues with the Pro Flo 1000 as it has been installed for a few days now.
Master Chief
Well, you're not a pinhead. Like me back in the 80's, you just did not know about those air filters. I ran them on two different vehicles and never had an issue. However, a friend mentioned that I should replace the filter because they have a tendency to melt or catch fire in the event of an engine backfire through the carb. Here are a few photos that I found on-line.
You may also want to pull the slack out of your plug wires and use proper wire separators. This will help prevent an ignition failure due to header heat damaging the wires. For example, here are several options that O'Reilly's offers. https://www.oreillyauto.com/shop/b/...-wire---looms---separators-17886/e795844a991e
bostonbronconut
bostonbronconut
Question Asker
Wayland, MA
Yikes - that's no bueno!
If I didn't use the original air cleaner, would the 1208 Pro Cleaner be a better short-term replacement: https://www.cjponyparts.com/edelbro...IxJ_8hOSY4wIVRP7jBx04AAoBEAQYAiABEgL37vD_BwE?
Master Chief
Says it has a 3" filter and deep flange base so that should work. The only issue will be if you end up with hot starting issues due the fuel peculating out of the carb. Edelbrock solved this problem with a heat insulator gasket, p/n 9266.
https://www.edelbrock.com/heat-insulator-gasket-for-divided-4150-square-bore-0-320-thick-9266.html
Here is a tech tip write up https://www.edelblog.com/tech-tips/resolving-heat-soak
If you have to install this gasket, you may have to get a shorter air filter. No big deal, you just have to go to the store and find a 10" round, 2 1/2" filter.
