I dont buy the heater core issue. At least not in broncos. As with the stock setup the heater core doesnt see any flow when the valve is closed anyhow. I can see having the system looped and having a issue but if adding a aux heater core fixes the issue then your issue was that your radiator doesnt have enough cooling capacity to start with either because of size or blockage.
The heater core really shouldnt be relied upon for cooling capacity.
my point was the loop, not a intact heater system with a flow valve, obviously with the valve closed when it is present is the same as capping off the system. I have seen it many times were for some reason either because of a faulty flow valve or core leak someone has looped the system and then fights over heating issues not realizing they are recirculating a hose flow of hot water. And even with a radiator that is adequate otherwise if you loop, then the radiator is not seeing that portion of the hot water to cool and your reintroducing that hot water right back into the block.
I agree that you should not have to rely upon the heater core to provide cooling but it is part of the system , I once went across the sever desert in Utah on a 127 degree day in a diesel Isuzu car that was nearly brand new and when pulling grade the ONLY way to keep it from over heating was to run it with no a/c and the heater on full blast full fan, it was not a comfortable ride but the small amount of extra cooling saved the day and the vehicle never had a heating issue otherwise .
ntsqd, yeah it was shadetree by a just out of high school kid (me) but it worked and my budget was limited and could not afford a newer larger radiator, it was a 67 mustang with a solid roller 351 Cleveland and a radiator out of a 390 car, but in stop and go traffic on a hot summer eve, even with a 6 blade fan and shroud it would overheat otherwise it was fine in all other driving conditions. so knowing the cooling system was just on the edge of adequate I added a large heater core from something on the farm and mounted it and it solved the issue, yes the real solution was a better radiator but you do what you have to sometimes even if a little shadetree.
