Cost for powdercoating?
Bigbird
I'm doing a frame off resto on a limited budget, if there is such a thing as a budget when doing a frame off!!! Just wondering what everyone is paying to get their frames powdercoated. I'm trying to figure the cost into my "budget"
Thanks in advance!!!
rojo23
Ashland, VA
i got a price a couple weeks ago for $1000. That included sand blasting, then epoxy primer powder (or some kind of primer coat), then satin black.
Greg_B
Cohutta, GA
1000 sounds high to me... I do powder coating but a frame is too large for my oven but I use a guy near me for stuff like that and I am guessing he would be less than $300 to sandblast and coat.... if you paid him cash :)
Greg
Crawdad
My guy quoted me $300 for sandblast and about $150 for powder coat. I saw a frame that was powdercoated not too long ago outside his shop. Looked great BUT!!! The very small nooks, crevices and crannies I saw some rust runs that can easily wipe off. Apparently the powder doesn't quite get all the way up in there. Seeing that sorta made me think twice. I may have him sandblast it then I will prime, seal and paint. Love to weld up the holes in the frame too, don't know why there are so many?!!!!
Greg_B
Cohutta, GA
Has anyone ever had a frame E coated then powder coated? The E coating is supposed to wick into all cracks and corners very good... then it can be painted over. Ecoating isnt supposed to chip or crack very easily either.
I dont recall ever seeing an Ecoating line large enough for a frame though.
Greg
DuctTape
Bozeman, MT
Have you looked at por 15? Some people prefer powder coating but painting it yourself with por 15 probably cheaper.
Crawdad
Greg, you have given my a good reason to go by and talk to my guy about E Coat. That should fix those small spots that don't get covered by powder. These guys have an oven that can fit a small truck in, it used to bake bread back in the day.
Por 15 is my next best choice. J man did his frame with it, look up his thread. He did a very thorough build thread. Very informative and a must read for DIYers!
addicted
Broussard, Louisiana
Im going with a galvanize dip and then top coat. Powdercoating looks great but if it does ever chip or peel its not easily touched up. I have a powdercoated front bumper on my DD. It got some rock chips and the bare metal underneath started to rust. The rust spread under the powdercoat and now it has bubbles starting to form. I guess it could have just been a poor powdercoating job but Im not going to chance it on a frame thats going to see alot of rocks and road debris
Pearlcoat
I have to agree with a few here in that if the powder doesn't get in all the nooks and crannies the surface will rust. Also if the area gets any nicks or stone chips it rusts also. I have some of these issues on mine now. A well prepared frame and good quality primer and paint will probably be much better in the long run and can be touched up as needed.
Greg_B
Cohutta, GA
Just an FYI here.... we do some work with John Deere , Kubota and some other outdoor equipment companies... Pretty much all of them require parts to be be sandblasted, Ecoated then powder coated. They must know something about how to protect metal that is going to be in a pretty harse enviroment. Ecoating is not UV stable so that is the reason for the powder coating... I am sure it also helps protect the Ecoating as well.
I can bid directly to those companies because we do not Ecoat. I have looked into adding that capability but as of now we do not.
Also, if you are going to powder coat... consider having a powder coat primer applied before the color. It is designed to get into all those nooks and crannies and it flows out more smoothly... it makes the powder look much better. All powder coats should not be applied very thick. 2 mils is plenty of powder... when it gets thick it cracks and chips much more easily. More is not better...
Greg
357Bronco
New Hampsha
Blast, prime, paint. Powder coating is the mystery coating that has taken on a life of it's own. Everyone has to have it, but no one knows why. Tougher then paint?, sure, but it's not indestructable, and it's not as easily repairable as paint. With the products we have today with the primers and sealers and paints, I'd stick with that route. Listen to Pearlcoat.
Greg_B
Cohutta, GA
I disagree with the repairable issue. If you scratch it just sand it out smooth and rattle can over it.. thats is what you are going to do with any other type of coating anyway. Why is this harder? Just choose a PC color that is easily matched with a spray can... we do it everyday at work. We also have a wet paint line but we cant sell it because it just doesnt hold up well and costs much more to apply. Powder coating should be less expensive than wet paint if the wet paint is done correctly. Now if you are doing it yourself I could see it being cheaper.
I am not trying to sell powder coating but I do have about 26 years of experience working with it. It was created to be a less expensive but more durable option in a production enviroment. It does have its limitations but touching up or repairing isnt one of them.
Greg
ghost66
My powdercoater quoted me $400.00 to sandblast and coat I think this is a resonable charge
MyOriginal66
I think I have around $800 for frame, cross member, radius arms and a few other miscellaneous parts (powder and sandblasting). It came out so smooth and glossy, my painter thought it was paint.
Also, my coater can do touch ups with a small heat gun, blends perfect!
jim3326
Appleturkey
My frame cost 450 to coat with silver vein and it looks real good. Don't have to worry too much about rust around here, only time it gets wet is when it's washed.
Jim W.
TN1776
As you are learning, powder coating prices are all over the board. The shop I've used seems to operate in feast or famine mode and if you catch them on the right day, their prices are great.
I would expect to pay $200-300 for a frame based on my local experiences. The concerns about maintenance/touch-up are valid but I have had such good luck with powder coat in that it tends not to need to be touched up as frequently as painted surfaces do. So take that for what its worth.
Bigbird
Bigbird
WOW, anywhere form $300 to $1000. I guess I'll have to go talk to the guy when I get home. The main reason I was going to have it powdercoated is time. I'm deployed with the military right now. I will be home in December but only for a month. I was going to drop the frame off to the powdercoat guy at the end of December before I leave on another deployment and pick it up in March when I get home. Thanks for the input.
Crawdad
I see ur from NY, if you keep ur EB inside and only take it out on sunny days you will be ok. BUT, and my opinion only, the harsh winters and salts on the road would keep me away from powdercoating. Again the powder doesn't get all the way in those tight spots and those will be the spots that you will see small rust drip stains. If u can have it sandblasted, you can primer it, seam seal all the nooks and crannies (or weld and grind down), and then you can paint it urself. Painting a frame can be done by most individuals. For less than $400 you can have a nice paint job far less than $1k and will hold up better than powdercoating jobs when put to the test found on northern roads in NY. Remember not to cover ur VIN plate on ur frame, may be in two spots and powdercoat may cover them up bc it goes on fairly thick. Don't beat me up, JMO.
winston vizsla
Birmingham
I work for the largest e coat/powder coating company in the southeast with tripple 21,000 gallon tanks and we can't fit a bronco frame on the line so Id be willing to say you'll have a hard time finding someone with the capability to e coat a car frame. We charge $800 to media blast and powder coat car frames. What a lot of people don't realize is that powder isnt powder. The $300 jobs are probably using cheap $3/lb powder that you can hit with a hammer and it will crack and chip off, as well as fade from UV exposure. The powder I used for my LMP bumpers cost $50/lb is is superior in for flexability when stressed, chemical resistance, and UV protection. I'm personally using POR 15 and top coat for my frame as I don't have the room for a frame off resto
