blainebrazil
88-93 mustang setup
On the lower intake what is the plastic port at the rear center of the intake for? It appears to have some sort of check valve in it.
On the underside of the upper intake there are 2 vacume lines and one has some sort of sensor on it. what are these for? There are also some larger threaded ports. 1 has a rubber hose attached to it and the other splits into 3 steel lines. 2 small and 1 a llittle larger. what are these for?
I also need to know what vacume line goes to the fuel pressure regulator? And where do I get the vacume for my power brakes and for c4 auto transmission.
any help is greatly appreciated
