Z Bronco
- Mar 17, 2007
- 1,141
A few questions before I finally get to start the conversion (cracking my ribs this winter has delayed things a bit). I have owned this Bronco since 1988 and it will be my only vehicle once everything is done. I have a 351W with the Lightning Lower and Explorer Upper and will be doing the Explorer serpentine conversion at the same time. I have a Duff hood bubble and a 2" body lift.
-On the EFI Heater tubes: I have the Mustang ones, but would it be worth it to use the Explorer tubes?
-I would like to put new bearings in all the serpentine pulleys. Are the Grainger bearings the best? They were the ones listed in the back of the Tech article.
-Should I use the Exp. Power Steering Pump and Alternator from the donor vehicle or just get new or rebuilt ones? Mileage is unknown on the donor rig.
-I am thinking of using a 1" spacer between the intakes and should have clearance since I am not using the EGR. Thoughts?
Thanks for your help.
Z Bronco
Z Bronco
