Coyote Engine - Parts List and Info For Install
Nickm1024cobra
Chicago Burbs
Any one have some ideas on the radiator hoses ? The top hits my fan and the bottom has to be twisted a little to fit so it kinda has a kink in it.
I cut that in half. went to the store and bought a random hose that was 1.5" or 1.5" whatever it is. bought a 3 dollar aluminum sleeve from summit and made my own. got to get a little creative.
Nickm1024cobra
Chicago Burbs
I have the duff bronco brake booster, even after cutting it down it’s so tight I can’t put the plastic valve cover on. Do they have a booster that’s no so big? I wasn’t planning on doing the hydro boost yet. Not sure the b/c coyote swap pump can handle all that. Any thoughts ?
hydratech for the win
Hemmer
Anyone have part numbers for radiator hoses that will work? How about hose size for vacuum and heater hose ? Trying to figure out how to run the smaller cooling lines and vacuum lines.
Hemmer
This will delete the oils cooler. The filter will still hit the support on the frame and the crossmember. May be able to find a smaller filter or modify the support. I’ll look for a new filter at auto parts store and keep u updated
BRONKEN
Morgan Hill, Ca
Installed the insert and the stock filter fits with plenty of room not sure why others are running/looking for the angled bracket from BC bronco's. Thanks Hemmer
Hemmer
That's weird, I have a 2015 motor and running the BC motor mounts on a 68 frame I wonder what's different. I will post pics when i get home tonight.
About how close is the engine from the fire wall?
mbhaddad
I received the BC Broncos replacement bracket the other day and went to install it today but it looks exactly the same as my stock bracket except the porting on the back is different. I was expecting it to be angled back or anything that would make it different.
Jamie Chriss
Torque Converter Question.
2017 Coyote
2015 6R80
I am running the 6R80 4x4 transmission. I need to replace the torque converter that came with the trans due to excessive damage.
Any recommendations
The torque converter that came with the transmission is ECXRA, not sure it is even from the same truck or not.
R
rguest3
I would get a stock replacement Torque Convertor for a 2015-2017 Coyote.
Geiri
Newbie
Iceland
Thank you for all this info. :)
Does the factory Mustan Coyote oil pan work in a Bronco?
Or do you swap for F150 pan.
Can you use the Mustang Steering pump I am going with MOAB Hydro Boost?
Or do you need a beefier unit.
And Shifters for the transmission What do you use? The mustang or the F150?
MidwestTexan
That's a great question. I bought Tumblin's (similar to Tom's) and Krawlers Edge (similar to BC)... With the KE mounts, the engine was 2.250" lower which I liked, but I had to notch the frame to clear the headers and alternator. The problem I didn't like was the front diff pumpkin was only about 4" from the oil pan. I went with the Tumblin mounts which raises the engine up and you don't have the clearance issues. It does put the engine at about 7* which looks kinda funny but It's suppose to help with pinion angle.
There's a trade off for which ever route you go. There are a ton of little fitment issues you're going to run into, but it'll be worth it!
Here's my build thread which I discuss the motor mounts a little more.
