Coyote Engine - Parts List and Info For Install
Hemmer
Got engine in to fit everything. Put ford manifolds on that everyone said wouldn’t fit. They fit right in. Unless I’m missing something the look like they will work. Just FYI.
R
rguest3
They look like they fit. Great job!
Right side clear frame OK?
Starter fits good too?
Hemmer
Starter almost fiits. It hits the frame and then bc engine mount. But it’s soooo close. May need to trim bc mount I’ll keep u guys posted.
R
rguest3
But the Manifolds do not interfere with the starter?
Which starter do you have?
Hemmer
I have the stock mustang starter. U can follow my build it’s called my coyote nightmare I post all the parts I buy and unlike a lot of people I tell u if the parts suck.
R
rguest3
The Powermaster 9132 starter fits great and is clockable, so you can rotate the Solenoid to any position you want. At the time, I purchased mine direct from Powermaster. Brand New model.
Hemmer
I heard about that I may go with that if I can’t get this starter to ft.
Hemmer
If anyone is looking for bolts I just picked some up from my ford dealer. I read they charge a lot so I never called. They had the cheapest bolts in town. Bolts for the bell housing to engine cost 1.15 a piece. I will post the part numbers once I make sure they fit. I also got the t case to trans bolts.
Jamie Chriss
I am considering going with a new Mustang Coyote, all the Ford options ship with the mustang 6R80 transmission, is it similar to the F150 6R80?
5.0L GEN 2 COYOTE POWER MODULE WITH 6R80 6 SPEED AUTOMATIC TRANSMISSION
M-9000-PMCA
Complete Modern Powertrain Solution for Any Ford
2017 Mustang GT 5.0L 435 HP Coyote Engine
6R80 Mustang 6 speed automatic transmission
Complete Engine Controller and Wiring Harness
Jamie Chriss
UTOMATIC TRANSMISSION 6 SPD 6R80 5.0L 4X4 FITS 15 FORD F150 PICKUP (9,000miles) Hmm what about this baby?
im interested!
Hemmer
im interested!
You can google the part number and it will come up I think. Still haven’t made sure they are the right bolts but they look like they are. I will double check when I pull engine again.
Hemmer
Does anyone have any ideas for mounting the computer? Does anyone have pics of the B/c computer mount installed ?
R
rguest3
I have done a Factory 5 with a DOHC 4.6L motor in the past. They have had great directions in the past with lots of pictures. I should have thought about looking there too. Great find1 Lot's of good info. The pictures really help.
Hemmer
Any ideas for the fuel pump I have an in tank 89 5.0 fuel pump they. Doesn’t have enough psi. The coyote needs 155lph at 55psi minimum I think is what the instructions say
Jamie Chriss
I am planning on running the 6R80 automatic transmission, with column shift. Is there any additional fabrication to the tub needed for the transfer case shifters to go through?
Is there any additional welding needed on the frame? I am getting ready to take my frame to powder coat.
transmission cooler, where is the best place to put it? I saw on one of the posts someone bolted it under the bed. I just need to know what areas needed to be fabricated before I coat the bottom of the tub.
Many thanks!
