Coyote Engine - Parts List and Info For Install
STalon89
I think you're going to have a hard time using factory headers. Even the custom headers dump out about a half an inch off the frame rail on the passenger side. Its super tight with the frame, starter and AC compressor all living in that same area.
Hemmer
Does anyone know a starter that will work that’s not the 400$ BC Broncos one ? I’ll be using the bc bronco engine mounts.
Hemmer
Little info for you guys this was sent to me by ford for the new ford 6r80 control pack. This allows you to do select shift. I guess the controller doesn’t come with true select shift. I thought that would be a problem with 4 wheel low. I also asked ford how the computer will know when to shift normal and when to go to select shift mode. They said they would get back to me. I’ll post that info when I get it.
Hemmer
First order to BC done
REDIRECTION KIT, 2015-UP COYOTE ENGINE
COYOTE HEADER INSTALL KIT, ONE SIDE
DASH # 5, CENTER SPEEDO WITH 5' OFF SET GLOVE BOX
COYOTE SERP KIT, A/C (part 1 of 2, add 15-00151 BKETS & SPACERS)
COYOTE BRACKET AND SPACER KIT (part 2 of 2, sold with 15-00151)
MOTOR MOUNTS FOR COYOTE
6R80 ADAPTER TO ATLAS
POWER STEERING BOX SPACER & BRACKET KIT FOR COYOTE
6R80 TRANS COOLER LINE FITTING AND BRACKET
Still not sold on $1000 headers Ken blocks coyote bronco uses the ford swap manifolds. Says they are modified. Thinking of trying them. If not it’s only 175 bucks wasted
American180
Mount Washington, Ky
Thanks for the wiring info. The 2014 F150 steering column I got uses a shifter with +/- and tow mode on it. I'm going to try and adapt it to my column. It's not as convenient but you won't have to deal with clock springs.
Hemmer
What fuel filters are u guys running for the coyote engine. I picked up this today think it’s for a Chevy. Don’t know if it’s any good just seemed easy to use with female thread ends on both sides.
R
rguest3
It is Brand Spankin New. So far, only direct from Powermaster. it can be found on their website and download Catalog.
Hemmer
Any ideas on a power steering remote resivoir that doesn’t cost 200 bucks ?
Hemmer
Do they make a bolt kit for the coyote to attach the trans to the engine?
R
rguest3
Hemmer - BC has a bolt kit you are looking for.
I found a Remote Reservoir on eBay with a 6AN return and 10AN feed to the Pump. - $50-60. Summit will have them too.
